How much does your computer weigh?
How heavy is your computer?
  • <20 lbs
  • 20-30 lbs
  • 30-40 lbs
  • 40-50 lbs
  • 50 lbs +
duragezic
11,234
4
I don't have a scale but it's pretty heavy.
Antec P180B
I voted 40-50 pounds but that's probably too much. Maybe around 35 pounds.
Nebor
29,582
12
I'm not picking my computer up, it has a bunch of hard drives just thrown in the bottom of the case and I don't want them moving around.
I'd guess 20lbs though.
CZroe
24,195
857
Mine is a beast. It's got one of those monstrous PC P&C TurboCool 1KW PSUs in it that's full ATX spec (much longer and heavier than "standard"). The steel case is frickin' heavy and the Thermalright Ultra-120 Extreme is one massive heatsink too. Additionally, there are two optical drives, six 5-platter HDDs, an external SATA bay with a seventh HDD, GTX280, 9800GTX+, and every card slot occupied (Tri-SLI board).
Here's how I know I'm in the top category without even weighing it: I attached one of those Antec LANboard roller things with the GearGrip-like handle and the snaps on the straps pop off when I try to pick it up. They can't handle the weight. I still leave it attached to roll it around, so that's even more weight.
14,092
I don't really want to unhook everything to check, but I'll guess mine is around 50-60 pounds. It is a pretty heavy duty case, not cheap thin stuff.
My server is probably close to 80lbs, big rackmount case, 6 hard drives. Was a beast to rackmount that thing alone.
I have 4 SAN enclosures too that are 127lbs each according to the label. Those were fun to move.
Meghan54
11,684
5,228
Well over 50#, but as others have noted, watercooling is heavy. A triple and a dual radiator, dual pumps, etc.
Silverstone TJ07 case and while it's aluminum, it certainly isn't light weight.
alkemyst
83,769
19
50lbs+ but the full tower steel case is 40lbs almost by itself (Addtronics 7896A)
HamburgerBoy
27,111
318
I'd guess no more than 30lbs. It's an Antec Sonata knock-off, the original of which apparently weighs 20lbs, so with all the typical motherboard, hard drive, heat sink, etc I'm probably close.
thescreensavers
9,916
5.6lbs :p
My Old desktop was in one of thouse huge thermaltake cases Xaer or something like that, it weight 50lbs dry.
Dubb
2,495
over 80lbs.
I run totally silent in a TNN500AF (over 70 just in the case)
what do I win?
ForumMaster
7,792
my case alone (steel case) weighs in at 21.8 pounds. the rest of my computer is pretty standard. so i'll go with between 20-30 pounds.
mugs
48,920
46
3 pounds. Desktop. Uses 10-15 watts idle. Dead silent. Doesn't function as a space heater. Plays Starcraft II well enough for me.
