Originally posted by: DrPizza
Originally posted by: SLCentral
my SAT's are average (2000/2600, 1350/1600)
You want to go to college and you don't even know what average means? :Q
Last I checked the average SAT score was in the range of 1000/1600. Did they dumb it down a lot?
I was referring to average for the college I'm looking at
. For that school, I fit in the middle 50% for both math and verbal.
1. Virtually no schools use the writing portion of the SAT; they may report those scores, but they don't use them (simply, because they can't - there isn't enough data on them yet to be able to use them as a predictor. I believe this year's graduating class will be the first with the writing portion. After that, the analysis starts.) You can forget about the 2000. 1350 out of 1600 is what they'll go by. And, a lot of schools don't just look at the total, so much as what each is individually. (Of course, they'll quickly weed out the people with 1000 SAT's without considering the individual components.) If you had an 800 in math, but only a 550 for the verbal section, that's not nearly as good as a 675/675. Although, if it's Princeton you're looking at, the average SAT scores were 730/730.
Who you know also helps, Dubya got into college
Anyone else can go
here for an idea of SAT scores considered.
However, I recently had a long candid discussion with the admissions counselor at my son's first choice school; not necessarily about my own son, but about what I should recommend my students (I'm a teacher) do in order to increase their odds of acceptance at the universities they want to attend. Yes, they probably have a profile of the high school you attended. They really don't care that much that you worked a part time job while in high school. If you're using that as an excuse for poorer academic success in high school, their question is going to be, "then why did you put more value on your part time job over your academic success?" What they're going to look at is how much you challenged yourself - did you take the easiest courses to pad your GPA in high school, or did you try to take as many of the most challenging courses possible.
Many schools also don't look at the specific GPA that you're thinking of as reported by the high school. They look at what your GPA is when you remove all the crap that's averaged in by your high school. i.e. if that 3.2 is as high as it is because you had a 100 average in phys ed for 3 years, you can count on them thinking a little less of you. They're also going to look at class rank - I don't know what your school's reputation is, but look at it this way: "Wow, he graduated from Harvard medical school?" "Yes, but he was ranked last in his class." "Hmmmm." Not all schools are treated equally in this consideration; it's based somewhat on the school's profile. i.e. someone in the 80th percentile at school A is considered on a par with someone at the 60th percentile at school B. Some schools are known to pad their grades, etc.
Also, at least the college where I had a long discussion, they use unweighted grades. Many schools weight grades from different courses differently.
Heck, I could go on and on with things I learned from the admissions counselor. Suffice to say, you better not have decided to make your senior year an easy year in high school, especially if you want to get into an Ivy League school. Also, every little thing you can put on your college application is important. As the counselor explained, if she asked a student to list their accomplishments, they'd be done in a couple minutes. If she asked that student's mother to list the student's accomplishments, she'd be going on for an hour or more. Stupid stuff that you wouldn't think matters, like, "First correct entry on the math challenge problem 4 weeks out of 16." Things like that help differentiate you as a student who really cares about everything academically related. (And, don't just limit it to academics.)
edit: For what it's worth, the admissions counselor is apparently a very good admissions counselor. My son's first choice school has the 2nd highest 4 year graduation rate. His 2nd choice school has the highest 4 year graduation rate. i.e. that counselor is VERY good at selecting students who WILL be successful.
