Originally posted by: Twista
Okay, took it out there in the snow. much better with all the weight back there. I can actually take off without the ass swerving badly. Yes, i did some testing and if i take off in the snow with alittle gas the ass end still goes nuts. But with the weight i can take off like normal and ALL is well.
Well you still need to learn how to drive. I'm not slamming you, but you should be EASILY able to control the power with the clutch and gas. Heck you could hold 1/2 throttle and still EASILY take off, at the expense of your clutch.
Something is very wrong if your ass is swerving. If when taking off you realize you have too much power and the wheels are slipping then depress the clutch somewhat to take power away from the drivetrain/wheels.
What year? Do you have traction control? Maybe spend a couple weekends in a snow covered parking lot to practice. Not only is it some of the most fun you will ever have, you'll learn a lot. Of course if you have summer tires or other tires that are not meant to be used in the snow no amount of skill can overcome hard snowpacked rubber on snow - it's like driving on ice. No traction whatsoever.
