hardwareuser
- Jun 13, 2005
- 136
- 0
- 0
Originally posted by: CycloWizard
You obviously don't have any idea what this thread is about. Based on your demeanor, I doubt it's worth even trying to tell you. But hey, I'm a glutton for punishment, so here goes nothing.Originally posted by: Intelia
Sorry it doesn't read like that and its still not possiable because the power supply well not operate at its max. for any extended time and that was not the question to start with . Also who would install a P/S that would only supply the same power as the system draws ? It would be a very unstable system !
The OP asked how much effect a computer's heat generation could have on room temperature. A typical engineering approach for such an estimation is to consider the maximum possible energy output of the system, as this will yield the maximum temperature effect of the computer on the room. This maximum energy output will occur at the power supply's peak power draw, since the input power must be output as heat. Thus, the peak power that the PSU can supply will necessarily be the maximum heat output of the computer.
That said, finding the temperature change in the room is still not trivial and dependent on many things, as described above by Navid. It will depend on the materials of the walls, ceiling, floor, any insulation present, and so on. All this because the problem is determining the steady state temperature of the room with and without the heat generated by the computer. As I said in my first post in this thread, it's extremely unlikely that, even at this maximum power consumption/heat output, the computer will have any real effect on the room temperature.
BTW, the input power of the PSU is usually not the same as its output power. That would mean 100% efficiency.
