Originally posted by: skimple
Originally posted by: slsmnaz
For most houses, go with a 50 gallon of a reputable company like AO Smith, Bradford-White or Rheem. Don't go get the Home Depot or Lowes special because they will not stand behind it.
HD & Lowes sell only name brand appliances. I bought a Richmond (Rheem) there. They don't sell a store brand, so I don't know what your comment means. Wherever you buy the water heater, the warranty will always be with the manufacturer.Prices vary widely. Do you need electric or gas? If you don't know, the easy way to tell is to see if your water heater has a vent stack coming out of the top. This will either feed into a fireplace chimney, or into a vent pipe to the outside. If you don't see a vent, then you have electric.
Water heaters are VERY easy to install. If you have flexible hoses attaching your current water heater to the water lines, you can do it yourself and save $150. If you have copper pipes connected directly to the water heater, then you have to have some skill in soldering pipe. If you haven't done this before, pay someone to do it. You'll burn up $50 buying a torch, solder, extra pipe, fittings, etc.
Tankless water heaters cost a LOT more than regular water heaters. Unless you have a houseful of people, you will not recover the cost of installing a tankless.
Correct, but you have to go through the vendor to get the warranty, it doesn't come from the manuf. directly.
It is very easy to do yourself. With IPS connections or the use of CPVC, you won't even have to solder (or buy a torch).
