How much does i3 2120 SMASH my old Phenom X3 720 BE that's very WELL OC'd? Skeptical.
Discussion in 'CPUs and Overclocking' started by Zeze, May 16, 2012.
  1. Zeze
    Zeze Diamond Member
    Mar 4, 2011
    8,298
    111
    Which one is better
    Your i5-750 (this isn't even on newegg)
    vs
    i5-2500k (only $5 more than 3450 until tomorrow, then $20 more)
    vs
    i5-3450
    So many god damn variants. I assume one of them is older generation but still good. Which is the best?
  2. N4g4rok
    N4g4rok Senior member
    Sep 21, 2011
    285
    Yessir.
    That little chunk of silicon has served me well. might look at an update around Haswell era.
  3. TakeNoPrisoners
    TakeNoPrisoners Platinum Member
    Jun 3, 2011
    2,600
    For gaming always look at GPU upgrades first as CPU upgrades won't make as much difference.
  4. Tsavo
    Tsavo Platinum Member
    Sep 29, 2009
    2,626
    8
    Both of which are dead sockets. Spending money on dead platforms is not a wise course of action.
    Core i3 2xxx + mainboard = less than $200 with the option of moving up to a modern SB or IB quad core in the future.
  5. Don Karnage
    Don Karnage Platinum Member
    Oct 11, 2011
    2,865
    You really want him to spend money on 1156? Its a dead socket
  6. Ferzerp
    Ferzerp Diamond Member
    Oct 12, 1999
    6,344
    46
    1155 is "dead" too if you want to get right down to it. Mainstream IB is the last proc that will use it. There may be a part with a minor clock bump in the future (think the 2700k), but other than that, the best is already out for that platform.
  7. Termie
    Termie Diamond Member
    Aug 17, 2005
    7,911
    44
  8. Don Karnage
    Oct 11, 2011
    2,865
    Problem is the 760 is still 10 dollars less then the 3570K. You really want to spend 10 dollars less for 2 generations less performance?
  9. Ferzerp
    Oct 12, 1999
    6,344
    46
    I'm not arguing with you there. Just pointing out that a platform with multiple generations of chips supported really doesn't happen with any Intel purchase.
    Some will argue that's greediness (I'd argue not, Intel makes very little on the chipset compared to the proc profit). I'd argue that it's more that they don't want decisions of 5 years ago hobbling their current development.
  10. Leyawiin
    Leyawiin Diamond Member
    Nov 11, 2008
    3,147
    40
    The i3-2120 is better, but its not going to bowl you over compared to your current system. If you truly want an upgrade go at least i5-2500k (and OC it). Question - is your current system causing you issues? Is there any program or game you feel its noticeably holding you back in? Otherwise, don't bother with an upgrade.
  11. Tsavo
    Sep 29, 2009
    2,626
    8
    ...riiiiiiiiiiiiiiiighhht.
  12. Arkaign
    Arkaign Lifer
    Oct 27, 2006
    19,305
    It's true though, Haswell will require a completely new chipset, and with the utter lack of competition from AMD, we've pretty much seen all 1155 has to offer, unless something incredibly surprising happens.
    I mean, it's *possible* that Haswell will keep the 1155 socket, but it's virtually guaranteed that it will be a different chipset.
    In all probability, it will be different socket and chipset though. Remember, the next gen of Intel chips is the biggest change slated since they went from C2Q to i7-9xx.
  13. Kristijonas
    Kristijonas Senior member
    Jun 11, 2011
    859
    4
    I had i3 2120. GTA4 stuttered. But only very little, almost not-noticeable. I had it with gtx560Ti and stuttering didn't depend on graphical settings.
  14. Ben90
    Ben90 Platinum Member
    Jun 14, 2009
    2,866
    Heh, dead sockets. I remember those threads were all the rage pre-Nehalem. I'm curious how many people on AM2+ systems have dropped in a processor that is faster than what LGA 1366 would have provided right from the get go.
  15. Tsavo
    Sep 29, 2009
    2,626
    8
    Missed my gist.
    1156 was dead from the get-go. Choice of a handful of processors with ZERO upgrades to new stuff.
    1155 offers compatibility with a nice range of processors from two generations of CPU tech.
    Buying an 1155 board is a vastly better option than buying an 1156 board and CPU.
  16. Arkaign
    Arkaign Lifer
    Oct 27, 2006
    19,305
    Ah, in that I most definitely agree. Although one might argue that the easier oc'ing of the 1156 stuff helped it remain competitive for enthusiast types for a decent amount of time (a high 3ghz to 4ghz range i5 or i7 pre-SB quad is still pretty solid for almost anything).
    The only reason to consider a 1156 setup is if you got a great deal on a used combo. I'd consider an i5-760 + mobo for maybe $120ish as a good option for someone to overclock with, which presumably would take it beyond i3-2100 levels. A 2500k though, that's the good stuff ;)
  17. Magic Carpet
    Magic Carpet Diamond Member
    Oct 2, 2011
    3,107
    2120 would certainly be better than your existing setup. But the question is.. do you need to upgrade?
    I moved to a Conroe setup and it's fine for my needs. Plays Solitaire just well :D
    #42 Magic Carpet, May 21, 2012
  18. Tsavo
    Sep 29, 2009
    2,626
    8
    I've got a moderately OC'd 750 (3.4GHz) which makes it decently faster than the Core i3 2xxx boxes I have. Stock clocks on each, and it's a wash though.
    I'm trying to hold out till Haswell to replace my main box, though I'm thinking of taking one of my i3-2xxx boxes and putting in a 2500k or 3570k to tide me over.
  19. sm625
    sm625 Diamond Member
    May 6, 2011
    8,175
    134
    I dont get the dead socket arguments. The 2500k was such a hot item that many people just dumped their 1156 stuff without even really considering the fact that its still almost as fast. So there are and have been some very good deals on 1156 stuff. But to say its a dead socket makes about as much sense as saying you shouldnt buy used furniture.
  20. Ferzerp
    Oct 12, 1999
    6,344
    46
    Exactly, it makes no sense in the Intel world to say "dead socket." They all pretty much are. They support at most a single tock and the following tick.
    Buy what makes sense now, when it's time to upgrade. The next proc you buy, is probably going to need another motherboard anyway.
  21. amenx
    amenx Platinum Member
    Dec 17, 2004
    2,061
    148
    Even if it wasnt a dead socket, its sensible to upgrade mobo anyway for a newer CPU. Because they would have newer chipsets optimized for the new CPU, and usually improvements, newer features not found on the older mobo.
  22. Ferzerp
    Oct 12, 1999
    6,344
    46
    What I don't like though, is the -E versions on the Intel side trailing behind the mainstream by so much. I went from x58 to z77 and lost dimm slots, pcie lanes (though not throughput, as it was pcie 2.0 -> 3.0), etc because there high end isn't out yet.
