How much do you think a PC repair shop would charge for this?
Originally posted by: pillage2001
Did you use the washers provided before you screw the board to the case???
if you mean the brass standoffs, yea, I did use them
EDIT: When I turn the power on, the fans start spinning but nothings else
replace the cpu next... its probably not the power supply.
then go to ram...
it should post without anything else.
then connect a vid card... then any drives...
that should be the order in which you try to figure it out
