Originally posted by: d3n
Paying for all the segments on a cross country dedicated T1 can reach 50k a month for some organizations.
you could always compress your data using bz2 format to save bandwidth. Unfortunately most people just throw more money (=bandwidth/hardware) at the problem.
can you show me how to do that with 3rd party banking software that generates about 8 gigs of data per day that needs to be mirrored live?
if you can you're hired!
If you're using SSH, you can turn on compression (it's off by default). This would be useful for protocols which are built on top of ssh, like sftp and scp, but most other protocols can be configured to use ssh tunneling as well.
again, how do you tell the federal reserve bank and our third party banking software to use ssh? on top of that...all transactions are required to use FIPS compliant SSL encryption? ............ EXACTLY!
let's throw more money and get back to the bandwidth/hareware solution eh?
That's because most smaller ISPs and most larger companies are now using T3/DS3 and OC3 for their own internet connections. Over time T1/DS1 is becomming less common.Originally posted by: w0ss
You might want to look at a burstable DS3 I was surprised how cheap they have gotten. Once you start getting into 3+ T1's the cost is usually not much more.
most companies here are throwing out the T1's and are replacing them with buisness sdsl or vdsl lines with SLA's
Thats becuase they are idiots
why?
Originally posted by: kextyn
A cable/dsl connection doesn't compare to a private T1 or higher. It doesn't matter what you use for compression. The line isn't going to be as stable or guaranteed. There is pretty much no guarantee for any speed with a cable connection.
Originally posted by: Cheesetogo
Why not OC48 - 2.48 Gbits
Originally posted by: dphantom
About 850 with local loop, 200 or so off our channelized DS-3. DS-3 runs about 2300 monthly. Looking at adding broadband into our mix for select areas. 10MB point to point in our area runs about 800 monthly.
