- Apr 17, 2001
- 3,650
- 0
- 76
My wipers are broken & I'm pretty sure it's the motor. I checked the relay & the switch, which leaves the motor or the wiring directly to/from the motor. Anyways I just picked up a new(good used) one for $10 & need to either replace it or check the wiring. The problem is that you have to pull off this cover that is basically glued to the windshield, and the weather is nothing like what I would like to be playing with glue, especially when I have no real access to a garage here. Do you guys know how much it would cost to have a mechanic do something like this?
