how much diferrence between
Pelu
1,208
sup all... I just need to ask.. because I dont have a way to test it...
but if i have a 3870 CF.. how much performance gain I will get if i switch to 4870 CF with my current processor and memory????
cusideabelincoln
3,275
46
It depends on the game you're playing and its Crossfire support. In some games dual 3870s can match or exceed the 4870 (Oblivion is one such game), and in other games the HD4870 destroys the Crossfire 3870s (games with no Xfire support).
Just look at Anandtech's benchmarks.
apoppin
34,890
alienbabeltech.com
Well, i would say my 2900xt crossfire was pretty close in performance to yours. A single 4870 is about 10% faster than it was.
So, not very much performance increase
- an X2 would be a solid increase!
Pelu
1,208
OH... The best move is then 3870 CF to 4870 CF...
3870 CF to 4870 isnt a big deal at all
apoppin
34,890
alienbabeltech.com
You can also go to GTX280-OC for $380 or to the 4850x2 for $400 or the 4870x2 for $550
- or 2 x 512MB 4870 CF for $500 .. or .. 2 x 1GB 4870 CF for $600
. . . just so you have plenty of choice
:D
imo AMD's best bang for buck performance upgrade from 3870 CF appears to be 2 x 512MB 4870 CF for $500 - less with the MiR.
i am selling mine to get the 1GB version
Pelu
1,208
hm... wondering if it will really make a diference with the current processor and memory... lol...
apoppin
34,890
alienbabeltech.com
Yes
You will be $400 poorer and graphics richer
it depends on whether you are satisfied with your current framerates and level of detail in your games
- only you can decide that
You also did not mention at what resolution you game
-you won't see much at 10x7 .. otoh, 19x12 will become fluid with 4870 x 2
Pelu
1,208
Everything runs fine... with around 2AA... never understand how people like those 8x.. or 16x AA and so on... kinda gets too blurry and drive me mad...
