Any chance of broadwell i3 being 10% faster than current i3?
What about its price?
^ thanks a lot dude
so with this it seems my best bet is the 4150 i3 with the less cache, from all those benchmarks the extra cache don't seem to do much at all
I am not buying mobile so how is lower power going to help me? this is a sad state of CPU affairs if you ask me, no competition a monopoly is so pathetic.
Anyways is the extra 1MB of cache in the 4330 i3 makes a big difference in gaming? I would have preferred the cheaper 4150 i3 thats same speed but only 3MB cache
the 4150 only costs about $109 but worried at how the less cache will affect it
It doesn't because while it is larger it's also slower. Same goes for 8 Cores with 20MB of cache and 12 cores with 30MB of L3, the latter is actually slower in ST performance because its cache is slower and the increase in size doesn't make up for this, same thing with 12 Core die and 45MB 18 core die, the cache gets slower once again. Unfortunately the larger cache also doesn't help the enthusiast platform (5820,5930,5960X) in ST very much aside from a very few limited cases.
Lets be careful here. Unlike HW-E and HW comparisons the i3 chips do not change the cache configuration, only the amount. Both have the same 4 MB on die.
Cache runs at the same speed but 1 MB is deactivated on certain models.
You are otherwise right though.
The larger cache has higher associativity, though. It used to be 12-way but now is 16-way associative, which means that it has become more efficient in terms of data hits but has higher read latencies. So, the positive effect of the larger cache is not obvious.
