is AVX only on in sp1 then? in windows update i don't see it as an option for me! :/
No?
Two non-concurrent LinX runs on my machine:
Logical threading may or may not matter in Power7 architecture, but I won't claim to know one way or another.
Yeah LinX is peculiar in this regard with Hyperthreading causing significantly reduced and inconsistent scores. Most CPU intensive applications do benefit from HT and even from those that don't, the end score is roughly the same.why are you turning off hyperthreading? am i correct to assume that's only to get top calcs on this benchmark, whilst you normally leave HT on?
i'm rather confused as to whether i'm getting the most out of my cpu at the moment !
"When host Alex Trebek finishes stating a clue, a human operator (who works for Jeopardy!) turns on a “Buzzer Enable” light on stage to indicate that contestants can “buzz in” and answer. At exactly the moment the “Buzzer Enable” light is activated, Watson’s system receives a signal that the buzzer is open."
The best human contestants don’t wait for, but instead anticipate when Trebek will finish reading a clue. They time their “buzz” for the instant when the last word leaves Trebek’s mouth and the “Buzzer Enable” light turns on. Watson cannot anticipate. He can only react to the enable signal. While Watson reacts at an impressive speed, humans can and do buzz in faster than his best possible reaction time.
IIRC, activating the buzzer is Watson's least advantageous feature used during the Jeopardy challenge.
http://ibmresearchnews.blogspot.com/2010/12/how-watson-sees-hears-and-speaks-to.html
Didn't you read the whole post? Linpack pegs FPU to full so using Hyperthreading gives you nothing. It means you even have a chance of getting lower score since the threads will still split the workloads up and cause contention.
But how many programs are only going to use the FPU? It seems to me that having HT on is very rarely a detriment to performance in real-world applications. I would assume that HT does help in most well-threaded programs.So this opens the question if a 2600 will perform worse than a 2500 when only 4 threads are used in other applications. There is not many times I need more than 4, so perhaps turning HT off would actually increase speed (and reduce heat).
Just to show some data to support these correctly stated assertions:
