how many partitions for a 42GB HD?
Modus
Partitioning a large drive into several smaller chunks is almost never worth the added hassle. Why?
1) FAT32 renders "cluster slack" moot. With the standard 8k clusters imposed on a FAT32 partition larger than 8.4G, and 16k clusters for drives around 20G, the average 1.0G of data will waste a paltry 20M of space. How do I know this?
Well, I recently did a survey of several computers I sold. To do this on your own machine, go to My Computer, double click on C:\, press Ctrl-A, and click File>Properties (ignore any message about the hidden files in your root directory, they're insignificant). A window will pop up showing you some important numbers. First, a count of the files on this drive. Then, under "Size", two numbers: the first will be the total size of all your files, and the second will be the total space occupied by all your files including wasted clusters. The second number will always be a multiple of your cluster size, and it will always be large than the first number. (For your cluster size, type CHKDSK at the DOS prompt, and read the size of each allocation unit.) By subtracting the first number from the second number, you get the exact amount of wasted space on the drive. It ends up being a lot less than you'd expect.
Another interesting number is the average file size, which comes from dividing the total file size (not the total occupied space) by the number of files on the drive. With these numbers, I calculated the average size of a file on a well-used Windows 98 drive. I found an average file on an average system takes up 150k, which means that an average 1G of data contains about 6990 files. A very good estimate of the amount of wasted space in any size data is
(Total Size of Data / Average File Size) * (Cluster Size / 2)
Why? Well, files are stored on your hard drive according to the rule that no two files can occupy the same cluster. If a file is smaller than a cluster, or if the file ends before the end of a cluter, the rest of the cluster is wasted. Logically then, an average file will waste half a cluster, since by probability the end of this file will fall in the middle of a cluster. So the amount of wasted space for a given set of data is the number of files (Total Size / Average File Size) times one half of the cluster size. You can check this yourself by doing the calculation on your own data and comparing it to the exact number Windows gives. It is actually a very conservative estimate, probably because the base Windows files are smaller than the files you accumulate later, and because a few large files can save a lot of space.
This formula tells us two things: First, bigger clusters waste more space (duh). Second, larger average file sizes waste less space. People with drives occupied by the relatively huge files of MP3's and graphics waste very little space. Of course, under Windows 2000's NTFS partitions, cluster slack is negligible, due to the tiny 512 byte clusters (same size as on floppy disks, actually.)
2) The performance gains from tinkering with the Windows swap file are dubious at best. You would probably be better off working at minimum wage and devoting the money to a hard drive or ram upgrade than spending the same time wrestling with partitions! Even placing the swap file on the fastest portion of the disk shows very little, if any, real world performance benefit. And think of the hassle in managing it all.
Real world hard drive usage is typified, not by continuous sustained transfers, but small seeks back and forth across the surface of the disk. Thus, placing a supposedly vital partition -- such as the OS boot partition -- on the outer edge of the disk will have very little effect on performance, because the it does nothing to improve seek times across the entire drive. And since long sustained transfers will rarely take place in the OS boot partition, its location at the outer edge of the disk is wasted.
3) FDISK is the only freely available partitioning tool and is hardly user friendly. You could go out and purchase Partition Magic or similar software, but for the same money you could just sell your old drive and buy a bigger, faster one!
4) Partitioning your hard drive will not save you time if you need to reinstall your OS. Why?
Even under a full-drive partition, Windows can be reinstalled on top of itself to fix minor problems, as can your programs if they become corrupted. This will take the same time regardless of your partition arrangement.
A common argument for partitions is that, with a small (600M or so) operating system partition and some kind of disk imaging software (Norton Ghost, for instance), you can restore a corrupted Windows installation in minutes. In reality, it just doesn't work this way. As soon as Windows is restored, the registry reverts to its default state and anything pertaining to your applications is lost, rendering them unstable or inoperable. This forces you to manually reinstall your applications to restore the lost registry keys. Of course, you don't have to restore your data, but any prudent individual would already have a safe external backup system, so all data could be retrieved easily from there.
So, the only time really saved by a small, OS-only partition, is the installation of the OS itself, which is not the biggest factor. In fact, the same time savings could be garnered by simply taking an image of the entire drive after installing all drivers/programs. This image, like any other important data, must be backed up externally, and once that is done, the partitioning scheme is again rendered redundant.
Many people argue that partitions allow them to backup their applications to a convinient storage area. This is weak because anyone with legal copies of their software will have the proper installation disks on hand. If certain programs downloaded from the Internet are important enough to backup to a serparate partition, then they are important enough to backup to safe removable media, rendering separate partitions redundant.
Personal data files, too, must always be backed up to some safe external medium, and since legitimate data files (financial records, written documents, contact lists) are so small, they often fit on a single floppy. Even if you work with large graphics, you must periodically back them up to some other external media, in case of theft, fire, or drive failure. And with CD burners so cheap and fast nowadays, there's no excuse not to backup your sensitive data in case of a hard drive crash. Hoping a hard drive crash will confine itself to a single partition is unwise.
The key point here is the backing up your data safely is an all-or-nothing business. You can't go half way and assume it does any good. To be prudent, you must take the proper precautions against fire, theft, or drive failure, and use an external backup device. Once that is done, partitioning holds very few advantages.
5) Partitioning does not help you organize your files. That's what folders are for. It is actually easier to keep track of your data files when they're all on the same drive, organized into different folders with descriptive names. It makes saving and navigation easier, too, because you never have to select a new drive to browse.
So we have basically eliminated all the reasons people give for partitioning data: It doesn't save you much space, it won't save you time reinstalling your OS and programs, it won't increase performance significantly, and it won't help you stay organized. About the ONLY thing partitions are good for is booting to multiple operating systems.
Modus
oldfart
10,207
I was wondering how long it would be before Modus did his cut and paste act. Look at any modem or partitioning thread and you will see what I mean. No, you don't want one gigantic 32k cluster inefficient partition. Modus will argue it like he does his winmodem thing to the grave. With a 42 gig partition, your cluster slack (wasted space) will be 30-40% or greater. That is unacceptable. A Storage review partitioning article says "Avoid 32K clusters like the plague". Comparing measurements on a 10 gig 8k cluster drive to a 42 gig 32k cluster drive is totally invalid. I wouldn't use any cluster size larger than 16K. At a bare minium, you should split the drive in half to get to 16k clusters. I'm not going to get into a back and forth debate with him about it. He will take this thread to 100 posts long until he gets in the last word. Look at all the responses and make the decision that works best for you. To answer your question about swap file size, I don't like a fixed size. If you have say a 3 gig Windows partition, just let a Windows controlled swap file live on that same drive. Since the contents of that partition will stay pretty static, you will always have a fast un fragmented space for the swap file.
ktchong
111
For me, the biggest benefit of partitioning is isolating disk fragmentation. The partition that accomodates all the swap, virtual memory, temporary, temporary internet files get fragmented easily and quickly. If I keep those files in a seperate partition away from the rest of the hard drive, then the fragmentation won't affect the entire drive; only one particular partition (the "swap" or "temp" partition) will be fragmented, not the entire hard drive.
Also, when I want to defragment my hard drive, I only need to do so on the "swap" or "temp" partition, which is usually less than 1 GB. If I have just one big partition, I will have to defragment the entire hard drive - 30 gig! That includes the program files portion that is not fragmented at all and does not need defragmentation. Defragmenting the entire hard drive is a true waste of time and effort.
If nothing else, isolating fragmentation is a good reason for partitioning your hard drive. For me, organization is another good reason. As for performance, I most certainly have felt an increase with partitioning (especially after a fresh defragmentation,) but anti-partitioner would tell you otherwise.
ktchong
111
SUOrangeman:
I've just read your "Dissertation on Partitioning and Multi-booting."
How did you put all the swap and temp files in the primary partition (I would assume it is also the outermost/faster part of the hard drive) and operating system in the extended partition? What drive letter was your "swap" partition? I thought Windows must boot from drive C.
aUt0eXebat
Banned
Oct 9, 2000
2,353
Ok, here is what I decided to do:
Is this pretty good? Will the performance be any better then just have one big C: drive?
C: 2 GB Windows (98)
D: 25 GB Apps (visual studio, office 2k and anything else)
E: 10 GB Games (half-life, soldier of fortune, etc)
F: 5 GB Data (images, backups, files)
-Total HD size 42GB-
oldfart
10,207
Looks pretty good. I would tweak it just a bit maybe.
C: 3 GB Windows (98)
D: 15 GB Games (half-life, soldier of fortune, etc)
E: 20 GB Apps (visual studio, office 2k and anything else)
Since the drive is so big anyway, leave the c: drive a little more room just in case (you never know). My C: partition has settled down at just under a gig of used space, but its nice to know I'll always have plenty of room if its needed.
I would put your game partition before the office app partition and make it bigger. Games are getting huge. 500-600 meg a pop adds up! Also putting it on a faster part of the drive may help (oh so slightly) maps to load quicker. The Word doc can wait :)
Good Luck!!
