Fayd
you need to get a nice 5.1 setup and a big hd secondary display and you'd be set![]()
I have an onkyo 5.1 and a 28" LCD primary monitor.
does that count?
Computer and TV are close, so I just run a video cable to it and have the TV set up as a second monitor.
edit: As far as QAM channels go, there's no way they're scrambled, pretty sure that would be against the law. You should be able to pick up digital channels with a QAM tuner. Don't listen to whatever the CS rep on the phone tells you, it's not uncommon for them to lie to try and sell you a cable box and other services.
does that count?
mixed results with my new hauppage 2250. the hardware and driver seem ok, but wintv7 is completely crapware. i'm going to look into gb-pvr but at first glance it seems bewildering.
Depending on your OS, you may have windows media center installed. Check that out first before you go and try new software.
