How low is too low for the 12v line?
Ketchup
14,559
248
I have a Skyhawk GM570PC 570-watt power supply and am using Speedfan to monitor my voltages. I noticed that the 12v line stays down around 11.71 while I am gaming and goes back up to 11.9 in windows. Is 11.7 volts cause for concern?
John
Moderator Emeritus<br>Elite Member
4
You should ignore software readings. Spend $10-$20 on a DMM to test the rails.
The rails should be within ±5%
Zepper
18,998
Yeah, Sears has their $20. DMM on sale t his week for around $11. Every home should have one...
.bh.
dBTelos
1,858
"The rails should be within ±5%"
So that would be 11.4V is the lowest you can have while staying in spec? Similarly 12.6V is the highest you can go while staying in spec?
w00t
5,545
I am going to have to go with John Here
JBT
12,094
agreed
Zepper
18,998
Navid,
. Yes, that's the one.
I concur with eelw or +/- 1V is fine in real life usages. The +12 rail is not used to power anything but drives and fans directly. For all other purposes it is reregulated down to a much lower voltage and filtered locally so as long as there is maintained a substantial ratio between the input voltage and the output voltage of the local regulators and the 12V rail is capable of providing adequate current, the output voltages of those sub-regulators will be just fine.
And the servo motors on drives can easily compensate for +/- 1 volt. The standard on the +12 used to be (and not long ago either) 10%. IAC, the standard for the +12 now is at +/- 5%. So if it measures outside that into a reasonable load (2A on the +12 and 3 to 5A on the +5 - yes both should be loaded for accurate regulation) with an accurate DMM, then the PSU is RMA-able. I don't know why software is so unreliable for voltage readings - it must be the cheap health monitor chips used in PCs these days.
. OTOH if you're measuring without a load (or too little of a load - the higher the Amp rating of a rail, the heavier the load needed for accurate regulation) then you won't get accurate readings as the regulation won't be working properly on most switching PSUs.
.bh.
SparkyJJO
13,357
7
Agreed, software reads my 12V line at anywhere between 11.69 and 11.86 but a DMM shows that it is actually just about spot-on at 12.01V with none of the fluctuations that the software reads.
