Hey all, have a home/web server that runs 24x7. I set up CrystalCPUID so I can lower the voltages and reconfigure the Cool-N-Quiet settings. Currently have it set up:
Idle: 4x200 = 800mhz, 0.875v
Middle: 7.5x200 = 1500mhz, 1.225v
Maximum: 11x200 = 2200mhz, 1.40v
Being a web server, running Win2K3 Server and Apache, usually sits at idle with a temp of 41c. Keep in mind this is a tower case with 4 hard drives and an Adaptec SATA Raid-5 controller all dumping heat into the case
How low do you think I can go on the voltages and still keep it stable?
