How long does your PC take to fully boot?
olds
50,124
779
Boot to windows?
Forever, it's hosed. Lost another RAID array.
SSP
17,727
Just a warning about prefetch thing. After running that program my system BSOD'd about 5 time now in the last 20 minutes.
Take that as only a mild warning, cause the OS was already in a bad shape. I just haven't had the time to do a clean install. I guess i gotta make time after exams.
I Saw OJ
4,923
Originally posted by: brigden
How long does it take your PC to fully boot; from the moment you press the power button to the split second the cursor stops displaying an hourglass?
I timed mine at 38.48 seconds.
I cant remember the last time my computer showed an hourglass cursor :p
seth
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
Boooo... Promise controller card without drives attached takes about 20 seconds to decide there's nothing attached + using ancient 10gig as OS drive right now as a temporary measure = about 2 mintues to boot.
nageov3t
42,808
83
from cold -> logged into Windows with firefox open takes about 30 seconds on my box.
Originally posted by: Twista
Originally posted by: Cawchy87
My computer -> hard drive -> windows -> prefetch
Delete everything in your prefetch folder and re-boot. It will improve you load times significantly.
If you do this too much it will slow down your pc.
says the guy whose PC takes over 6 minutes to boot up ;)
revnja
2,864
I haven't rebooted in 72 days. Pretty damn fast though, as far as I can remember.
ucdbiendog
2,468
1 min from power on. After it passes through all the BIOSes n stuff, maybe 15-20 secs. Runing windows XP pro. my rig is in profile
konakona
6,285
i thought disabling prefetch has adverse effects (speed wise) on many of regular windows operations... or so i was told.
0roo0roo
64,795
84
i used to care. but windows stable enough now that i don't reboot much anymore. pre xp rebooting used to be so important. it was a sad time.
Eli
Super Moderator | Elite Member
8
Not very long.. about 45 seconds.
Realitivly fresh install.
Aves
12,232
30
101
I would know because I always use hibernate. That takes about 20 seconds or so.
Juno
12,574
Haven't booted for long time. Already passed prime95 test but I don't know how long this computer has been up since. I think two weeks ago or so.
Amused
57,388
19,699
I so rarely reboot, I don't know.
I do remember the Windows XP slider bar on the boot screen slides across 4 times before the XP desktop pops up.
