how long does azureus take to load??
jiwq
it's been stuck at that Initializing Plugin: SafePeer for about the past 30 minutes. sometimes it takes 30 seconds to load, other times, it just doesn't.
man, hurry up and load so i can download my.................... linux isos. yeah
takes a minute or two for me....slows at the same point. Hooray for........Linux ISOs - the current ones I'm downloading are AWESOME - lol
Originally posted by: suse920
Originally posted by: dug777
Originally posted by: klah
About 5 seconds, but I don't use that plugin.
yeah well for me, it's important that i have the safepeer plugin so that the mpaa or riaa isn't snooping on me while i download my........ linux isos. i just dont like being watched 😉
Don't use Safepeer and it will only take 3-4 seconds to load.
Who are you trying to block, anyway? It's not like the FBI/MPAA is on your tracker...
I got two 'cease and desist' letters before I started using Safepeer (both for downloading TV shows). Since I started using it, I got none.
Safepeer does make Azureus take about 1 minute to load on my linux box, though. But, it's only a 900mhz Athlon.
Pretty quick, but if I have very large (>4Gb) torrents that are not complete, then it does take a while to start up. Presumably it's doing some form of checking on those files. *shrug*
SafePeer takes 11ty years to load because it has to check the server for and obtain a new blocklist. The server is slow as goatballs. IIRC, you can set an option that causes it to sync up the list AFTER Azureus is done loading.
