How Is Your System Handling UT 2004 Demo?
thebestMAX
7,509
1700xp+ Oclocked to 2.1 and just an 8500le 128M vid card here.
Seems to be running buttery smooth with the install defaults here.
How are you guys doin?
ElFenix
102,402
8,574
xp 2000/166 (oc'd fsb) 1 gig ram, 9800 pro, full options, 4x fsaa and 16 tap aniso on performance and getting peak of 40 fps :(
need a faster proc i think. i wonder if my ram will hit 175 or 200?
EDIT: 1280x960 res
bsmithy
458
1024x768
everything full
6 x FSAA
16 x AF
9800 pro 128
2500+ @ 2.315
512mb Crucial xms 3200 @ 432mhz
= 70-80 fps constant & buttery
Viper GTS
38,107
433
Christ, turn down the AA/AF! Video card is the primary limiting factor on that, & since you're already running a 9800 Pro there isn't much room to upgrade.
I'm running a GF4 Ti4200, runs great at 1024x768x32. No AA or AF of course.
Keep in mind that the demo uses lower resolution textures than the final will have, so when you crank the eye candy in the shipping version it will hit your system a lot harder.
Viper GTS <-- Wants a new video card for Halo/UT2K4
EngenZerO
5,099
1800+ (not o;cd)
512
ATI 8500 (64mb)
runs rather smooth @ 1280x1024 with everything on normal
ElFenix
102,402
8,574
yeah, i know, and this isn't exactly an rpg or something where i really notice the jaggies. i'll still overclock some more once i take the system apart and apply some arctic silver. i dont think this arctic alumina is working as well.
Electric Amish
23,578
Running sweet right now.
XP 2600+, 1gig ram, Radeon 9700 Pro, 1600x1200.
Haven't tried turning on the AA yet.
CChaos
1,586
This is a very important thing to note. Don't worry too much about the eye candy yet. Netcode, physics, weapon balance and gameplay are the priorities. The game will look very very nice with Holy Sh1t settings and will tolerate quite a bit of dumbing down for older systems.
That said, it's fine on a 3.2Ghz P4/Abit IS7-E/1Gb PC3200/Sapphire 9700 Pro system, but if it wasn't, Epic's developers would all need to be shot.
FuZoR
4,422
1280x1024 highest possible settings on the demo... runs nice and smoooth.
Radeon 9600 Pro on a P4 1.6A @ 2.4 w/ 1GB PC2100 ram.
kami
1024x768, everything at max...runs great even with 16 bots in the game (the bots took much more of a performance hit in UT2003)
Athlon 2400, 1.25GB, Radeon 9800 Pro
Suppose I could run at a higher resolution but not much of a need.
SarcasticDwarf
9,574
1024x768 (32) with a 9600 pro and all settings maxed out. Runs smoothly.
The only complaint I have is when you alt-tab about, everything even outside fof the game runs sloooooooooooooooow........
SWScorch
9,520
runs ok, albeit with low settings
AthloNXP 2100
512 ram
GeForce2 Pro (the weak link :()
38
2.4c-stock
2x256 3500 hyperx
9500@ 9700 pro
40gig 2meg(getting 1208 mb soon)
1024 @ 67-75 fps all high afx4
rky60
1,077
XP2100
512 PC2700
GFTi4600
1600X1200X32 runnin all the in game goodies to max, or at least I think I am. No FSAA or AA or whatever tho...
Very smooth, no stutters even durin' mass chaos. How do I check my FPS in it? ~ Key then ??
yllus
Elite Member & Lifer
Aug 20, 2000
20,577
432
P4 2.53GHz, 512MB DDR, GF4 Ti4200.
Max everything at 1024x768, doing 50 fps constant.
Entity
10,090
P4 3.06, 1gb RAM, Radeon8500, seems a bit sluggish. May have to turn resolution down. It's at 1024x768 right now.
Rob
ElFenix
102,402
8,574
the first unreal couldn't be played on any current systems, pretty much. unreal for unreal requirements ;)
Fritzo
41,920
2,161
P4 overclocked to 3.1Ghz, 512MB RAM, ATI 9600XT (with built in overclocking enabled)...Smooovvv
Got all the goodies turned on, playing online @ 1024x768. 1280x1024 was a little chunky, which is the default res of my LCD monitor.
Ne0
1,227
14
1024x768, Everything on Max, 2x AA, 4x AF running very smooth
2.4C @ 3.0, 1 GB Dual Channel Ram, Radeon 9800 Pro.
