J jamesdsimone Golden Member Dec 21, 2015 1,007 286 136 Feb 14, 2025 #1 Just wondering, everything seems to be running as usual but the last few days it's been doing that.
maddogmcgee Senior member Apr 20, 2015 414 426 136 Feb 14, 2025 #2 Did you turn it to 11? Reactions: Tlh97, Thibsie and jamesdsimone
H Hitman928 Diamond Member Apr 15, 2012 6,755 12,502 136 Feb 14, 2025 #3 Are you on Linux? Some resource monitors treat 1 core as 100%, so if you had 8 cores fully loaded, you would see 800% utilization.
Thunder 57 Diamond Member Aug 19, 2007 4,296 7,103 136 Feb 14, 2025 #4 IIRC Windows 7 did that when overclocking as well.
J jamesdsimone Golden Member Dec 21, 2015 1,007 286 136 Feb 14, 2025 #5 maddogmcgee said: Did you turn it to 11 Thunder 57 said: IIRC Windows 7 did that when overclocking as well. Click to expand... This is on Win10. Click to expand...
