Gamingphreek
Originally posted by: Capt Caveman
Originally posted by: geekified
If it hasn't been said, I believe the 3DNOW! instruction set also plays a role in the gap, as well as AMD's better memory management with the lack of the external front-side bus. In general, the tech community thinks AMD X2 (dual-core processors) to be better than their Pentium D equivalents due to performance superiority, less energy usage and all in all better stability. That being said, Intel's entry-level processor the 820 costs significantly less than the X2 3800+.
The debate will always rage on, but the margin doesn't seem to change much, AMDs are not dramatically better than Intels of similar quality for gaming, on the whole, besides maybe the FX processors. If you want better game performance, you're way better off buying a new video card in most cases.
Completely wrong. Programs needs to be coded for the 3DNow instruction set and almost none are due to Intel's large market share. So, that's not the reason for AMD's better performance.
An X2 3800+ can be had for a little over $300 and in the course of a year, will be cheaper(lower electricity bills) and vastly outperform a 820.
All you need to do is look at any gaming benchmarks and a AMD dual-core destroy's any Intel Pentium D(not including the Presler).
Dual-core is pretty much the only way to go nowadays. Nvidia and ATI's latest drivers have been developed w/ dual-core in mind(not mature yet but will get better). Newer games will become multi-threaded. And if you're like any normal user, a dual-core will free-up cpu resources for gaming, as one core will take the load for any anti-virus/background programs that you maybe running.
3dNow and its variants are useless. Barely any programs use them. THe programs that do use them are programs such as SuperPi and math intensive applications. Games will show no improvement.
Instead of 3dNow! designers followed intels SSE(I)(II)(III) instructions. Notice again that there is no difference in gaming, only in encode decode, and calculations (Super Pi).
Once again, nether SSE (Streaming SIMD) nor 3dNow have ANY affect whatsoever in gaming.
As for AMD's performance advantage (for the 9999 time):
AMD's instruction pipeline is much wider and shorter than intels. While Intels is IIRC 31 stages, AMD's is estimated to be around 14. THis means that the instructions reach the execution stage of the pipeline much faster, whereas Intel must increase the clock speed in order to keep up.
This also is where Hyperthreading comes into play. Because Intel's pipeline is so long, a cache miss or error halts the entire pipeline for IIRC 12 Clock Cycles (If it is L1 Cache at least). Hyperthreading sends another packet through the pipeline before the first is completely executed. Therefore the entire long stretch of pipeline is filled and working as close to the theoretical maximum as possible.
A Processor has nothing to do (unless over clocked) with the systems stability. THat lies in the chipset and the software within.
ohhhh i see, now for gaming.... a amd 4000+ is like a 1 lane highway at 100kmph and the amd x2 4800 is like a highway with 2 of those lanes. but one is closed... for now.
Ummm no not really. If in the sense you mean that each lane equals an instruction pipeline, memory controller, ALU (etc...) then yes the lane parts would be correct. However, i am not sure what you mean by "one is closed". Both cores are working. However when you are only running one task at a time, or when you are running a task that is not SMT (Multithreaded) the other core isn't used and remains idle until it is needed.
Play at a high enough resolution and the GPU always will become the bottleneck. Intels processors can still be used for gaming, they just aren't as quick at it at the lower resolutions as an AMD based system.
Most definitely. However, AMD still holds a couple frames per second lead at high resolution. Nothin to write home about or anything, just ~2fps here and there.
Get the highest Mhz AMD - or - highest Mhz Intel you can afford.
I still dont know why people say the highest Mhz/Ghz. WOuldn't the correct terminology be "the highest clockspeed".
At any rate that is a waste. The absolute best bang for your buck right now is, if you can find it, the Opteron 165. If you cant find it then get the X2 3800+. There is no need to go for the 4000+ or the 4200+, the 3800+ is only marginally slower and if you are so compelled you can EASILY overclock to reach that clockspeed.
Ill try to find some information on SSE and 3dNow and MMX if you want to read them.
-Kevin
