GamerExpress
Banned
Originally posted by: professor1942
Yeah, 2x1GB is a better choice for AMD64 systems. And the difference between CAS 2.5 and CAS 3 will be like 0.5 fps.
Yep, and you also want to run it in 1t
Originally posted by: TriggerHappy101
Also: Why does the nForce 4 ultra chip(set) limit ram speed to 3200? 4200 is cheaper and faster no?
Originally posted by: ribbon13
Not particular to AMDs, but is significant to the K8/K9s because of the specifics of AMDs on-die mem controller. If you're going for AMD performance, avoid 2T at all costs.
Order of importance:
command rate (1 or 2 DIMMs only!)
DDR
timings
DDR
timings
Why avoid 2t and what does that mean???😕
