viivo
I recently popped the heatsink (stock aluminum garbage with the black spring poles) to check the core (didn't want to flash a r350, luckily it wasn't), then cleaned it with alchol, applied AS Ceramique, etc., usual process, and re-installed the heatsink. Through testing after the flash I found the heatsink, while not scorching, is enough to cause pain if touched for too long, and it's much hotter, obviously, than before the flash. Is there a chance of damage if the stock heatsink is left on? My case stays fairly cool, and there is a side panel fan blowing directly at the card. What worries me though is ATItool displays artifacts shortly after attemping to find max mem or core, forcing a restart, but I've noticed artifacts in no other application or Artifact Tester.
Thanks.
EDIT: Fogot to add there is no LM63 chip on the PCB, so I can't check the temp of the core.
EDIT 2: Ack, meant to post this in Cases & Cooling. Oh well.
Thanks.
