Originally posted by: bupkus
So if the voltage I set in the bios is different from the voltage that is reported by the bios, which should I believe? As for cupz, it seems to be fixed at 1.6V which according to AMD's specs is off by .05V.
the voltage that you set in the BIOS is the most accurate you will get
Now, as far as believing cpuz vs. believing the bios, doesn't cpuz just report what the bios is sensing, just doing it after the os is installed?... I dont' know.
