How hard is it to smash a building with a plane?
amdhunter
23,332
249
Outta curiosity, how hard is it to aim a big ass plane into a smallish target like a building?
Like, is it as hard as driving a car? My RX-8 is pretty maneuverable, and I can pretty much point it in any direction, and it instantly goes. I'm sure I can smash a building with it, with ease. Is it the same with a jumbo jet?
I always imagined you'd have to start aiming from miles away to really pinpoint a building, or have military-like training to be as precise as past attempts were.
What is the minimum amount of feet it would take to pinpoint a building with a jumbo jet? :confused:
vi edit
62,484
8,345
Grab a copy of MS Flight Simulator and give it a shot?
SandEagle
16,809
13
its different from driving a car. no minimum amount of feet required since acceleration and decceleration is done by hand. by hand, Jerry!
LTC8K6
28,520
1,576
For the WTC towers, it's a bit easier. You could program the flight controls to take you right to the buildings and only have to make the final small adjustment yourself.
For the Pentagon it's a little tougher because of the ground level.
The problem would be getting used to the relatively sluggish movements compared to a car.
Eli
Super Moderator | Elite Member
8
I don't think it would be very hard mid-flight, like the WTC, as long as you knew the basics of how to fly an airplane. Especially with such large, obvious targets. Both planes hit very accurately.
I think they did mess up on the Pentagon a bit - they did major damage, but I'm sure their goal was a more direct, in the middle hit rather than what happened.
vi edit
62,484
8,345
How does the degree of difficulty compare to maneuverering straight down a trench and skimming the surface to this point. The target area is only two meters wide. It's a small thermal exhaust port, right below the main port. The shaft leads directly to the reactor system. A precise hit will start a chain reaction which should destroy the station. Only a precise hit will set off a chain reaction.
SunnyD
Belgian Waffler
Jan 2, 2001
32,675
www.neftastic.com
I knew this was coming sooner or later.
GundamW
1,440
Porkins: But first, I need a bucket of fried chicken.
AMCRambler
7,715
31
That's not that hard. I used bullseye swamp rats in my speeder and they're not much bigger than 2 meters!
fatpat268
5,853
WTF?
But no, it's not exactly difficult. Of course, large jets can't turn on a dime, so yes, it'll take some time to setup (partially also because you'll be moving at a pretty decent speed).
It's such a ridiculous question that's almost like asking how hard is it to land on a runway... when competent pilots can do it without problem (without navigation assistance).
ioni
619
11
lol, that's not a bad idea. I always figured they'd block crashes or something.
Did you think they'd remove the building from the game the instant you aimed your plane at a building? Even if there was no actual collision, you don't think you'd be able to tell when you were right in front of a building?
gevorg
5,070
1. IP Address... recorded.
2. Gathering location data... iPhone... complete.
3. Identifying user... new black guy avatar.
4. Lock target by nearest sniper... target locked.
5. Fire!... target eliminated by SEAL Team 6.
CptCrunch
1,877
Flight Sim 95 had crashes into Sears tower in Chicago with my Learjet and Cesna, not sure about Flight Sim X
