Neat.
30 some years ago when I was a stoner I envisioned going .999999999999 the speed of light and then I would have a telescoping bowl that would shoot out and hit the speed of light and I would be smoking pure enegery! Good bye NSA job!
Does this mean Einstein was wrong? Or just that we are going one way and the galaxy is going the other way so the total distance between us is growing faster than the speed of light?
Very cool. I'll briefly pretend I understood all that while I post my reply.
Nothings actually moving. It's all a lie.
Did a double take on the last bit, is that accurate?
The part about photons not being able to outrun a galaxy and it not being visible... Doesn't sound right.
In my understanding in relation to it's photons the galaxy is moving at normal speeds, and they will keep doing their thing unless occluded from the observers perspective.
I've always wondered what space is expanding into....
I've had trouble with that, too.
I believe the answer is essentially that it isn't expanding into anything. There is no 'new' space being formed out at the 'edge' of the universe. It's just that the distance between everything is growing. Think of if as a slowly inflating balloon. With a bunch of planets and space bullshit floating around inside of it. But unlike a balloon, the the stuff inside it is getting less dense instead of more dense as the balloon grows.
The 'edge of space' thing is still troubling, though. As in, the universe is 13 billion years old, and we have observed objects roughly that age (albeit we're seeing how they looked close to 13 billion years ago)...why would there not be anything past that? Wouldn't it just be a 'false horizon' of sorts?
All this sounds like theoretical physics bullshit. It may appear to travel faster than light but it really isn't...
It may be interesting to note that at even while sitting still we're all technically moving through space at about 2.7 million MPH.
http://blogs.howstuffworks.com/2010...re-you-moving-through-the-universe-right-now/
