- Aug 25, 2001
- 56,587
- 10,227
- 126
I suspect you'll run into much of the same with the Q6600 systems, especially since they're only really economical to upgrade to 8gb at the most RAM-wise (DDR2). Add in some of the other limitations of your typical Q6600 system, ie: BIOS instead of UEFI, etc., for booting -- and yeah, the platform will find itself obsolete in a few years simply on that account.
Also, those boards have what, SATA-150 or SATA-300? Think rebuilding a RAID of 2-4 20Tb hard drives with only SATA-300 is going to be fun?? (my 2500+ board started life with a 40gb HDD and ended with 500gb HDDs -- so a scale factor of 15X isn't unrealistic!)
Similar deal with video. Embedded video is clearly the way of the future for most people. If you have some 8000x5000 display -- why buy a $70 video card to run it, when $70 is half way to a new motherboard with the video embedded?
That's an interesting comment. It does seem unlikely that 1TB 512byte-sector HDs are going to remain on the market for more than a year or two, at the current pace.
I'm hopeful that someone, somewhere, will come out with a GPT/EFI loader program, that boots off of a USB flash drive, enumerates your drives, and allows you to boot off of a GPT partition to an EFI-compatible OS. (Isn't something similar used by Hackintoshes?)
As far as video cards go, for UHD resolutions like that, I would just pick up another video card, with whatever new digital output interface is necessary for those monitors. I somehow doubt that PCI-E is going away any time in the next 5-10 years. We might be on PCI-E 3.0 or 4.0 by then, but hopefully, they will remain backwards-compatible, if a bit slower because of that.
