How fragile is that green top of the AMD CPU's and rounded cable question
the FooL
789
First, how solid is top of the CPU's (SlotA, Duron, T-Bird)?
Is that the core?
I noticed that the sides of the top of an Athlon classic I have are
jagged, as if chipped.
I had been rocking it back and forth for a bit trying to get the heatplate off/on.
I want to know if I have to be careful.
Also, is there a potential problem with rounded cables generating electromagnetic interference with the cables bunched together like that?
I'm assuming that the normal cables are not shielded.
Wouldn't this interference degrade the performance for the ATA 66/100 and SCSI devices?
lsd
1,184
70
BE VERY CAREFULL!
I already cracked 1 duron while i was trying to mount my HS on it.
miniMUNCH
4,159
When mounting your CPU and HSF, just don't breathe and you'll be fine.
What cables are you talking about? But anyway, the answer is no. Digital singals are filtered regardless of signal purity and any interference that a digital singal induces on other signal line is minimal , especially for such low voltage and the fact that your singal line (cables) are not running parallel to one-another, right?!;) You'll also notice that many of the small wire cables(e.g. analog sound from CD to sound card) are twisted; this is done to minimize induction/crosstalk between the wires and interference from other sources.
As long as you don't have your wires taped together in parallel, or something silly like that, interference should not be a problem.
Bring's up another good tip, using category 5 phone line (twisted pair) can improve your modem/dsl connection speed.
Usul
1,016
Vodoo rituals are required, and human sacrifice is recomanded!
Seriously, BE CAREFUL, and try to put the plate flat from the beginning of the process.
No interference, neither in ATA100.
the FooL
789
I'm talking about the 'rounded' cables people are using to improve airflow and lessen the _wall_ around the hard drives.
I noticed that people would cut them up in strips, then tape the strips parallel to each other.
Sort of forming a rectangular assembly.
Man... I better be careful with my Duron when the cooler comes in.
Rockhammer
148
Go ahead and round your cables, just be careful. If you don't want to cut them, just fold or roll them and tape them.
The core is very, very fragile. If yours is chipped it might already be dead. Hit the link in my sig and check out the pics of the tiny chip that killed my first duron. While you are there you can check out my guide to replacing the little sponge rubber feet with hard ones that do a better job of protecting the core. Good Luck!
lepper boy
1,877
taking off and putting on a heat sink is a special art.... especially on these new flip chips..... Just breathe slowly, take a deep breath and go for it....... my trick I do,,, (so I think it's a trick) just put gentle pressure on top of the heat sink and fan until you have the clips unhooked or hooked up. that way you aren't rocking it back and forth.
