VirtualLarry
I've got this friend, that I sold some parts to, that has the same GSKill DDR4-3000 16GB RAM kit that I do, in the same model Gigabyte motherboard. Mine works fine at XMP settings. His does not, it doesn't even work at 2666, it triple-posts while beeping, then restarts at default (2133) DRAM settings.
What am I doing wrong with his rig? He's not overclocking. I had him go to BIOS, "Load Optimized Defaults", and then go the MIT menu, "Advanced Memory settings", set XMP to "Profile 1", which should set Mem. Freq. to 3000, and Mem. Voltage to 1.35V (which it evidently does). But it won't POST at those settings, not even when manually set to 26.66 Memory Multiplier (2666Mhz DRAM).
I'm guessing that it's failing the "DRAM training" that Ryzen rigs do on boot, but why? Could the RAM simply be bad?
His mobo has F25 / AEGSA 1.0.0.6 (which for my ASRock boards, actually fixed a lot of memory-compatibility issues). My board has F21, which says "Optimized for Bristol Ridge". I have a Ryzen R5 1600 CPU though, not a 1200, so possibly binning plays a role here in DRAM freq. possible?
He has been getting BSODs and lots of browser tab-crashes in Firefox, which leads me to believe that the RAM has something to do with it.
PSU is a Rosewill 600W 80Plus Gold, that I'm also using in a mining PC right now, his was opened new for his rig. The DRAM was new or basically-new. Mobo was a refurb.
Was planning on getting him a new 16GB kit of DRAM, probably the Corsair 2933 16GB kit, or possibly the Team Vulcan Z 16GB kit.
