How does letting an ink jet cartridge run out damage a print head?
mshan
I've seen warning about how letting an ink jet cartridge run out before replacing can permanently damage a print head.
Can anyone tell me the actual mechanism of damage?
Also, do those ink jet print head cleaners I've seen on eBay (advertised for unclogging print heads) actually work?
Inkjets use a heated filament wire to "sputter" out the liquid ink.
If there's no more ink in the cartridge, the wire just heats up air, which can soon lead to the filament burning itself up.
Keep a few spare empty ink cartidges and refill (using a syringe) with Windex (or other ammonia-based liquid cleaner).
Then run the printer's head cleaning utility.
Any potential damage from Windex?
And is that what the ink jet print head cleaners on eBay are?
EDIT: could I safely just take the print head out of the printer and drip some Windex on the print head itself? (would it be safe to drip water on afterwards to clean out the Windex)?
I clean printheads by putting very hot water and a little ammonia in a paper plate then let the printhead(only) soak in the water. I usually replace the water a couple of times. I then tape a folded paper towel on the prinhead to draw out all the ink and then refill. If you've put windex in the cartridge you can get it out using a paper towel taped to the printhead. I'd then refill with water and paper towel it a couple of times to get all the windex out. It will usually take two towels to get all the fluid out.
We all have to remember that most ink jets are thermal---but Epsons use a piezoelectricity method to basically vibrate the ink onto the paper---which sadly mostly does not work well enough often earning the Epsons the name clogmasters. But at least Epson users don't have to worry about printhead burnout---and everyone else does. But once a printhead burns out, its forever---but it can be minor if its just a few elements in thousands.
But the other problem to worry about is a clog---but since inks are mostly water soluble---water will always work---but once the clog dries hard---it often won't work fast---ammonia which is no longer present in most modern windex works faster---as does rubbing alcohol--but both do have some potential to dissolve electrical contacts in printheads--so use them in low concentrations---and only at the clog sites. The fastest and safest way to increase clog dissolving speed is heat of about 130 degrees F or so---and Bill Kunert is exactly right about paper towels being used to apply solvent to the only the clog sites.
But of the four major inkjet printer manufacturers---Lexmark and HP group together by placing a cheap printhead on each cartridge---and the user pays through the nose for each cartridge----Canon use a separate and higher quality thermal printhead---and can vend cheaper cartridges---and gives the user a printhead the user can easily remove and replace--and clean easily. Epson has a separate and high quality non thermal printhead---and can vend cheaper cartridges---but by design prevents the user from easily removing, cleaning, or replacing the printhead---which sadly Epson sticks to---and as a result does not get the market share they could get if they lost some of their own stupidity.
Would it be safe to just leave the canon print head in warm water overnight and then let it dry out completely for say a day?
To mshan,
Probably not---too likely to damage the electronics and joints in the printhead---which is an assembly of various pieces glued together--with water possibly affecting that glue also.
But many threads on the nifty stuff forums on cleaning Canon printheads.
