How does BF1942's key system work? EDIT: THE BATTERY HAS BEEN REPLACED, TOO.
0roo0roo
64,795
84
ah k that makes sense, i guess its auto flack height sorta:) just didn't feel logical that the flack would explode at the right height... guess i shouldn't think so much.
Murphyrulez
1,890
Always look at your crosshairs when shooting, you will see them turn into a X when you score a hit on someone....
Originally posted by: ness1469
Originally posted by: rival
Originally posted by: Chaotic42
Originally posted by: 0roo0roo
i think u have to reinstall to get the new key to work. clean the registry too.
sorta ot, but how do u guys use the anti aircraft guns. do you lead on your shots or aim straight at the damn plane? its damned hard to know if ur hitting anything. and once it becomes totally obvious at point blank range, that doesn't help much
Lead. Watch where the explosions happen, then lead by that much.
<---- A real PITA on AA.
yea, i think when you see black smoke kinda explode, its a hit
The AA fire explodes even if it's not a hit... it's called "flak". If you start shooting it before the plane comes over head and just keep shooting, you can move the explosions towards the path you are predicting the plane will take. You can usually count on one of two things... one, the person in the plane sees the flak and decides to take you out, or two, the person in the plane sees the flak but thinks they are cool enough to make it through... in either case, if you lead the flak a lot, then narrow in as the person gets closer, you will pretty much always do some heafty damage at the minimum. If they look like they are coming for you, unless they are really good, they might as well go ahead and select their spawn point.
or you act like me...run like hell outta there, fly around for 30 seconds, come back behind yo ass and tear you up! :evil:
