thats all you want to put together because its more fun for you to act like an ass which I guess makes you feel superior.Because something something some guy on a forum somewhere, and 540p looks like poop. That's all I've put together so far.
should I copy and paste everything for you so we can start the same exact debate all over again?I'm sorry, what was your explanation again for why 1080p can't scale perfectly to a 4k screen again? Since we're all so confused, and you're not, perhaps you could take the time to put your fact-based explanation into one comment, so we can end this silly debate (if that's what you want to call it).
While toyota isn't explaining himself very well, and is wrong about pixel doubling, a lot of scalers don't use pixel doubling. So even if you should be able to get a perfect lossless scale, they still interpolate the resolution and blur it all to hell. So in other words, this would have to be looked at in a product by product basis to see which 4k displays have true pixel doubling.
Of course even if the monitor didn't have true pixel doubling, the scaling could look decent, since the interpolation algorithm has such a high DPI to work with. Still, I would never assume it looks fine without seeing it, as too many scalers stink.
Ideally, but manufacturers aren't often looking to cater to the niche of enthusiasts who know about this stuff, and I'd never buy a 4k monitor without knowing for a fact it had it. Maybe that's just me.I'd say with the wide availability of 1080P content 4K TV manufacturers would have to support pixel doubling in their scalers.
thank youI have a 2560x1440 monitor and 720p still looks like crap, even though in theory every pixel in that resolution should just map to four physical pixels in my monitor and it shouldn't look any different then a native 720p 27' monitor, unfortunately it does look worse.
lol that's hard to believe, who started that rumor? Samsung?But over at [H]Zone, I read that everyone will be on 4k by Xmas.
Try the MPC-HC + MadVR combo and you will be pleasantly surprised. If you need help with them there are a couple of sites with nice guides for them and setting up the subs properly for your player.
If you're running a crappy player that doesn't even do a bicubic resize on 720p sources it's no different than going full screen in a web based flash video.
It was already set to perform scaling on display.go to the Nvidia control panel and disable GPU scaling and try that again. If it does look worse, it's only due to crappy scaling, and absolutely nothing in the world to do with the fact that it's "not native" like Toyota has been insisting this entire thread.
thank you
I tried 1280x800 on my Korean 2560x1600 monitor that only has a DVI connection and no scaling built into the monitor.
The AMD scaling that is done is much worse than I expected. Everything is fuzzy. It definitely doesn't just map one pixel to four for the higher resolution. Is there a way to get the AMD software scaler to do this?
