Yeah the only way that works if you do it as a cardio exercise such as doing supersets without any rest in between for 20 or 30 minutes.Originally posted by: Skoorb
I will cut myself if I ever again read how toning can be attained by different rep amounts. I am serious.
Yeah, and then you'd probably be better off just splitting your workout with weights followed by real cardio!Originally posted by: Red Dawn
Originally posted by: AndrewR
I do two body parts per session, trying to do two sessions of each per week with one day off. Right now, I've been doing legs/triceps, chest/shoulders, and back/biceps, but I might be switching to chest/triceps and legs/shoulders. I do about three exercises per body part so six per session, varying numbers of sets depending on how I feel that day but generally around 3-4. I half-pyramid the sets, typically 12-10-8 or 10-8-6 (or 12-10-8-6). Each session has one big compound movement -- squats for legs, bench press for chest, and deadlift for back. That compound exercise is done first at the peak of my energy level, and I usually do 4 sets not including a warmup set at low weight.
Best advice for starting out? Don't go heavy on your first tries. You WILL regret it and can hurt yourself fairly badly. Learn the exercises with easily handled weight and train your muscles to respond to the new stimulus. You also will need to start slow to build up the small muscles that are probably very weak, like your forearms. If you try to sling some heavy weight on bicep curls, for instance, the top of your elbows will be in massive pain for days, and you won't be able to extend your arms.
i'm not trying to be an a$$ but i thought I would give you some advice. first of all, working out (as in lifting weights) 6/7 days a week is too much. you want to work out the same muscles like once every 5 or 6 days, not once ever 3 or 4 days. thats too quick and you aren't letting your muscles fully recover. second, you don't have abs in there at all. yes i know everyone says "oh i do abs real quick between exercises" which is a huge misconception. your abs are just like any other muscle. they n eed to be worked like any other muscle. however, they are the hardest to physically see because the fattiest area of your body is your belly.
You are KILLING your possible gains with that split. You train your triceps, then the day after with no recovery time you hit your chest and shoulder workouts, both which use the triceps as a major supporting muscle group. A better split would be the one you suggested - triceps/chest, biceps/back, legs.
Originally posted by: TheLonelyPhoenix
I typically do my whole body in one workout, 3-4 times a week, hitting as many different muscles as I can (two sets each, both done to failure). I typically aim to be lifting just enough weight that I can break 10 reps the first time and 7 reps the second time. Usually I know that I did a good job if I'm having difficulty walking or carrying my backpack by the time I leave.
On alternate days with my lifting I do cardio, usually treadmill. Sometimes I'll go play basketball instead.
I'm not a big fan of whole body workouts because the more compound exercises you do, the less energy you have. I used to have a four day split with two different workouts that had legs, back and biceps and chest, shoulders, and triceps on alternating days. While it was comprehensive, I found that the biceps in particular were not getting a full workout because by the time I had done squats, seated cable rows, lat pulldowns, and leg presses, I had very little left for some good reps on barbell curls and seated dumbbell curls.
Full body workouts are good for starting out to get a baseline fitness, but after that stage, you want to start separating out the body parts. Even then, I don't like them because you'll tend to favor the exercises that come first.
Whatever works for you though!
Originally posted by: Zysoclaplem
I hear alot of guys talk about going to the gym for 2 hours. But from what I have seen, most of the guys at the gym do about an hour of working out. Then walk around, talk, and bullshit the rest of the time. I find I can work everything I need to work in about 45 minutes.
Originally posted by: Kaido
I've decided to buy a bar and some weights and get in shape. So how do you work out?
You're supposed to alternate days, right?
