How do you take staples out?
Just knock out the support structures and the staples building will fall like a house of cards.
Checkmate.
I think you could do it yourself. I'm guessing they're like a not fully closed paper staple. If you clipped it in the middle, you could remove each half by kind of rotating it out. Grab it with pliers perpendicular to the staple, and twist, while lightly pulling. Kind of like you would a hognose staple that's caught up in some material.
This.
But be sure to soak the wound in warm water first, makes removal easier.
(Had my daughter remove 7 staples from my back, she was familiar with staple removal since she removed ~25 staples from her own abdomen after her surgery!)
Do they itch yet?
You wil learn fast how to scratch that itch after dragging your nails across the staples just once! :biggrin:
Sounds like a very painful experience D:
Glad you're okay & the worst thing you're worried about now is how to get them out.
I got about 10 staples in my knee from a cut a few days ago. I usually would stitch myself up and pull them out but I ran out and no medical supply place had quantities less than 1000. So I went to my Dr who put staples in. Anyway do you just cut them in half and pull from either side?
Ran out of super glue?
