Hi all. I was searching for some 'ware to monitor Vdimm voltages on my P4C800-E Deluxe. I did the Vdimm mod on it a long time back, and never found a way to monitor it.
I saw several message boards/forums state that MBM 5 would do this. After installing the SOB, apparently that's a lie. They said that the entry "Core 1" is Vdimm, which defaults to 3.00v, but on mine it defaulted to 5V! Also, after setting that up with the alarm, "Core 1" on my install shows ZERO volts so the alarm keeps going off! I'm hoping someone can tell me what the problem is and how to get this to work. Also, I saw that "AiBooster" will monitor Vdimm on this mobo, but I thought I'd ask if that's also a lie before I install it. Why is it only available as a download for the P4P800 and not the P4C800?
Thanks.
Thanks.
