PhoKingGuy
In the ER we use KY jelly to get stuff removed, I've yet to see it not work
Tell her you've been banging your secretary.
She's 5'4" and 125lbs.
Put her hand in some ice cold salt laden windex, slather both of you up with vasoline, and pull the ring off with a string.
Go down to your local FD and ask them to cut it off, they carry ring cutters. A small piece goes under the wring and then a tiny grinding wheel you turn by hand cuts through the ring, and then you just bend it open.
bolt cutters
Same suggestion. It makes a very clean cut that is easy to repair. I also know some jewelers that will remove it free....so they can try to get the repair work.
Seriously I have cut several rings off with the ring cutter, and it's painless.
BS. Pics?She's 5'4" and 125lbs.
LOL, these are exactly the kind of responses I expected.
The forum doesn't look or feel like ATOT but the responses sure do. 😉
