- Oct 1, 2004
- 3,290
- 0
- 0
I can hook up my pc with dvi input to my television.What option i need to press,activate to make my desktop go to the television?
thanks
thanks
Originally posted by: ifesfor
How do i set my nvidia pc card on my television?
Carefully on the top, so it doesn't slide off.
Sorry, couldn't help it.
anways, you should be able to select it right there in desktop settings and check the "use this device as my primary monitor" option.
