How do I remove the Tuniq Tower 120 backplate?
Rubycon
Madame President
Aug 10, 2005
17,768
485
Originally posted by: aigomorla
Originally posted by: lamere
Originally posted by: Gillbot
Borrow or go buy a cheap hairdryer.
i'm doing just that. hopefully it will work. i looked at heat guns yesterday and they were all in excess of $50.
be very careful with heat guns.
If you apply too much heat you could melt the solder on a cap or worse. :X
:laugh:
Rule of flame!
If it's hot, keep the damn thing moving always! If you're using an industrial heat gun never put it closer than 3" from the target (in this case) and ALWAYS keep it moving. Holding it stationary can do serious damage - 800°F air vs. 380° solder melting point. :Q
A hair dryer is much safer for the novice to use and will produce sufficient heat to soften the adhesive.
lamere
479
it was a LG775 backplate so i just used the LG775 kit from the new heatsink and wallaaaa everythings good
thanks all
