How do I patch and then recompile, or rebuild, my linux kernel
Brazen
4,259
Well, It produced an rpm, but for i386 instead of i686 and also a src.rpm. I installed it but it gave a "grubby" error and when I rebooted the system hung trying to find boot info.
So I started over, went through the instructions I had gathered and installed the resulting rpm with # rpm -ivh kernel-blah.rpm
It installed with no errors, but when I reboot there is only the option for the two default kernels already there. I think I saw what to do when a kernel install doesn't update your grub configuration, so I will have to look into that.
edit: Well that was easy enough just did:
# mkinitrd /boot/initrd-2.6.13-DeadGatewayDetection.img 2.6.13-DeadGatewayDetection
and added the info (copying the existing entries) to /boot/grub/grub.conf
Now I would just like to have it compiled for i686 instead of i386. running
rpmbuid --rebuild --target=i686 kernel-2.6.13DeadGatewayDetection-1.src.rpm
on the src.rpm created with the kernel rpm.
Brazen
4,259
Well the above rebuild did not work! :|
INSTALL sound/pci/snd-via82xx.ko
INSTALL sound/pci/trident/snd-trident-synth.ko
INSTALL sound/pci/trident/snd-trident.ko
INSTALL sound/pci/vx222/snd-vx222.ko
INSTALL sound/pci/ymfpci/snd-ymfpci.ko
INSTALL sound/pcmcia/pdaudiocf/snd-pdaudiocf.ko
INSTALL sound/soundcore.ko
INSTALL sound/synth/emux/snd-emux-synth.ko
INSTALL sound/synth/snd-util-mem.ko
INSTALL sound/usb/snd-usb-audio.ko
INSTALL sound/usb/snd-usb-lib.ko
INSTALL sound/usb/usx2y/snd-usb-usx2y.ko
if [ -r System.map -a -x /sbin/depmod ]; then /sbin/depmod -ae -F System.map -b /var/tmp/kernel-2.6.13dgd-root -r 2.6.13-dgd; fi
+ cp /var/tmp/kernel-2.6.13dgd-root/boot/vmlinuz-2.6.13-dgd
cp: missing destination file
Try `cp --help' for more information.
error: Bad exit status from /var/tmp/rpm-tmp.44759 (%install)
RPM build errors:
Does anybody know what these errors mean? It almost looks like if I just create the vmlinuz file and put it in /var/tmp/kernel.../boot/ then maybe it would work? Anybody have any other ideas? Is there a way to create the vmlinuz file that it appears to be looking for?
Brazen
4,259
Originally posted by: Seeruk
:laugh:
oOOH linux how I love your simpleness
My ultimate goal is to have a dual wan router with dead gateway detection for failover ability. Can you do that with Windows? :D
n0cmonkey
42,936
Here's the important part:
Not sure how to fix it, I haven't messed with RPMs much.
Seeruk
986
:laugh:
No reason why not :)
Anyway sounds cool :)
Brazen
4,259
:laugh:
I'm beginning to wonder if it can really be done in linux. I'm having troubles, even after patching the kernel, it doesn't seem to want to fail over.
M00T
1,214
write a bash script to change the metric on the dead port and cycle the ethX init scripts.
