How do i know if my cpu is overheating
BmXStuD
1,474
What the avg for a cpu to be running. Mine is a Duron 1300 no overclock it runs @ 50c and in q3 for awhile bout 54c.
System temps stay @ 36-37c
(q3=quake 3 arena)
Also someone ask if my memory overclock or underclock i dunno, or even how to change it?
ALso i am using the regualr thermal pad that came on the cpu i didnt add anything.
I get this now on my 1 day old post so im made this new one
Sorry, we were unable to locate the object requested.
Error Code: 102
Markfw
May 16, 2002
27,141
16,037
Those systems temps are pretty high. What is the room temperature where you are ? Given those case temps, 54c for the cpu seems normal, or at least fine. Over 65c would be abnormal.
xXgambitXx
691
i'd say those temps. are alright. if you want to bring them down though it wouldn't be that tough. just grab a nice $10 heatsink from newegg or svc and some thermal paste.
BmXStuD
1,474
i dont know the room temps. All i know is its my room :/ Cae now @ 35c
50c for cpu this is the norna temp when boot up also IDLE or not its always 50-54c.
I take it.. its bad if it boots up 50 :/
The HS I GOT IT:
http://www.tcwo.com/cgi-bin/webc.cgi/st_prod.html?p_prodid=2469&sid=1gi2Ty0l4M4l7hP
main site is:
http://www.coolermaster.com/products/cpucooler/fcpga/dp5-6j31c.html
when i 1st build it i accidenly scarted some thermal pad stuff off i thoihht it was a peel off.. heh 1st time builder mistake! but i doubt thats it b.c it should melt on the die anyway.
is this good?
http://www.newegg.com/app/ViewProdu...e=0&propertycode=&propertycodevalue=3185,3753
Markfw
May 16, 2002
27,141
16,037
With the room at 35c, then a 50c boot-up temp is fine. You need an air conditioner....... That 95 F !!!!!
BmXStuD
1,474
;-( than why does it crash when it want. ;-(
grrr Shuttle!
bad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcbad pc bad pcv
Markfw
May 16, 2002
27,141
16,037
We need details on the crashing and what software is installed.
Markfw
May 16, 2002
27,141
16,037
Did you say you had a 7200 or a 7500 Radeon ? The 7200 isn't very good, but the 7500 is OK. The heat thing can also affect your video card. You said it only does it in games. Take the cover off the PC, and put a big fan (like a house fan) blowing directly in the area of the video card. I only suggest this due to the high ambient temperature in your room(95cf,35c), and the fact that HOT video cards can make a display show "artifacts" or hard-lock.
BmXStuD
1,474
I got a new video card. I got this card lastnight a gf4 mx440se and its doing the same. I got a fan on it now and still i dunno. Back to playing quake3 and saying my results w/ a fan on the chipset
W?ith big fan idle its @ 30 room temp and 47c for cpu on HIGH and loud!
