How do I keep other people off a 98se computer? 1 more question.
purplecow
Don't use passwords for users in Win9x, it's completely useless. You can just press the ESC button and it boots up like normal.
jaywallen
1,227
Yup, pretty much useless, unless everybody just has to have her/his own wallpaper or something. :D
Topochicho
338
thant can be disabled, we have the machines at work setup to only allow entry with password, no Esc or cancel will work.
buck
12,273
4
Thanks jaywallen, thats what I needed. I know its worthless, but I dont want my wife to deal with seeing it everytime. :D
Thanks!
Matt
Courtland
703
in win 9x/ME the passwords are encrypted in a pwl file. so lets say you have a user named blahman, the file would be blahman.pwl located in your windows directory. you can just delete this file and the password is removed and the user is gone.
vi edit
62,484
8,345
Use poledit, set up users, and then tell it to require a password before booting into windows. You can no longer escape past the login, or just type in another user name and password.
jaywallen
1,227
Well, we shouldn't actually say that it's useless or worthless. If someone likes it, it's not worthless. When I said "useless" I just meant that the functionality of User Names / Passwords on (non-networked) Win9X PCs is pretty much limited to "window-dressing" features. Being a curmudgeonly old geezer who still distrusts anything but the "green screen", I tend to feel that Windows brings out the interior decorator in all of us. It may be good for our artistic sides, but I suspect that it interferes with productivity. :D
I'm glad the information was helpful, Matt. You might want to get your wife a cattle prod (or that rottweiler) to fend off the twinkies who keep attacking her keyboard!
Best regards,
Jim
bacillus
14,517
should you want to persue the bios password route, then set a bios password & change the hdd detection from auto to none! the system should not boot till detection is put back to auto!
Phatty106
170
If you get sick of the BIOS password, you can use a program such as this.
It only costs $15 to register, and it seems like it has lots of features.
phatty
