Method 1: Turn off texture compression in Q3
seta r_ext_compressed_textures "0"
in your q3 config file.
Method 2: Force DXTC3 instead of DXTC1. Get a tweak utility like nVmax. There is a setting under compatibility that will have the option to force DXTC3. It can also be done via reg entry, but how and where depends on the OS you run.
