How do I delete a post...?
Okay, this is a test. This is a test. I'll post again & then edit it out which is probably the only way you can delete a post.
Yep, that would be the only way. I cut and pasted the "this is a test" to msg below it, then clicked edit and deleted the msg. Notice the "Edited" info at the end of the msg above.
You are not allowed to delete your posts because (I'm not sure if this has happened, but it would if deletion were enabled) trolls would come in and incite the masses, and then delete their thread (and thus all the replies within it) before the Moderators could find out about the situation.
