Originally posted by: JoeKing
Yes it can
Originally posted by: sygyzy
For all of you who says "my time is never off ... it auto-updates", that is an oxymoron in itself. Your clock is ALWAYS off, that's why it has to update itself. The OP and others are talkinga bout keeping accurate time.
Originally posted by: LuNoTiCK
I figured the cmos battery helps would do matter.
Uh.. hello?Originally posted by: BigJ
Auto-update refers to a scheduling feature in Windows XP that syncs your time when you specifiy it. There is no oxymoron there. It's just making sure that your time is synched. If it is, everythings good. If it isn't, then it gets synched.
It could be either what Minendo suggested (dying CMOS battery) or what dullard suggested (damn programs that always mess with the clock).
If your clock needs to be synced, that means it was inaccurate.
Originally posted by: Sysadmin
Originally posted by: minendo
Because you are an idiot.
Seriously, just replace the cmos battery.
DING DING DING WINNAR!!
Sysadmin
Originally posted by: Armitage
Originally posted by: Demon-Xanth
Because your $1500 computer's primary purpose isn't to keep accurate time.
Well, that's a pretty weak excuse. For alot of things it's more important for my computer to keep accurate time then a $5 walmart watch.
Originally posted by: 3chordcharlie
There's a GREAT program from GATOR that will keep your time absolutely perfect... wait for the pop-up that says 'your clock may be wrong' then click it and answer yes to absolutely everything they ask.
Don't read: just click.
please to do this unfailingly 😛
Originally posted by: CorporateRecreation
because your 10 cent cmos battery sucks or your power supply sucks.
That's about the best solution out there but the fact that you have to run a separate program just to sync it really sucks. I wish there were an installable service so I wouldn't have to see that thing in the systray all the time.Originally posted by: JoeKing
Yes it can
Yes it can
Yes it can
Windows can do this automatically. Just double click on the clock on the screen.
Edit: I just wish it was a 24 hour clock.
Also, I'm pretty sure the really expensive automatic watches, such as Rolex aren't as accurate as the less expensive battery operated quartz watches.
