By the way oil and fuel heaters? Block heaters yes some have heaters in the fuel /water separator but most don't. I'm sorry I did not know I was typing a novel or a article for the the newspaper so I am just casually typing and really don't care about punctuation or what you think about it.
AGAIN PROOF ME WRONG. You told me I gave terrible terrible advice ,that was based on your opinion only no facts to back it up at all. I know how much a truck holds and it was stated in my previous thread about that .So switch to a smaller engine 5.9 liter Cummins
the oil change interval is 15k on standard oil. We have a lot of these engines in our equipment and a lot of the have 8000 hrs or more and still run strong.
You guys make statements and give no fact to the reason why I need to be changing my syn oil every 3 thousand to 5 thousand miles. Nobody around here can have a decent discussion on anything without turning it into a big Pis-ing match and then the name calling starts and the grammar errors and all that bull only shows that you have no interest in opposing viewpoints or facts .All I want is facts that prove my statements are completely wrong and my advice is completely without basis. I have years of proven change interval studies and numerous articles and and analysis sheets that prove this fact .
Jeff7181 I totally agree that yes they do see less in the way of cold starts and yes engine start up is where a lot of wear occurs but not all of it. Where I went to school for auto diesel they used to say 70-90 percent of all wear is at startup. But with the evolution of oil and oiling systems in the new cars and trucks I would say that number is lower now. I will see if I can dig up the study Caterpillar did they concluded that acid and particles in the oil was the main engine wear factor.
Give me facts not rederik and opinion. I have to laugh at people when all they can do when they have no facts is try to make the the opposing viewpoint look bad by trying to make them look stupid when in fact they are the ones that look stupid and uninformed
Challenge me on what I have said here
1. Type of oil used is crucial in how long you can go between intervals
2.Crankcase ventilation is a major factor in how long a engine can go between oil changes
3.Type of filter medium used and quality of that medium
4.Conditions that the Unit works in
Always use oil analysis to determine change intervals I totally agree ,conditions that the vehicle encounters I totally agree, but to say to someone that they give bad advice to people is just totally uncalled for. Inform yourselves then you make the decision on how to go about it.
I stand by the statement that 15k or around 15k should be fine as long as all the factors in determining that are met. You are throwing your money away if you change your syn oil at 3k Under normal circumstances. I understand that there are circumstances that would cause you to change earlier but as I stated before for a over the road every day driver vehicles it's not needed.
To do it right you need a baseline on the engine oil to see how far you can go on a oil before a change is needed .Change accordingly
I just can't believe that people are recommending oil changes on syn oil at 3-5k most manufactures recommend 7500 miles what a waste of time and money for a stock over the road car or truck .That recommendation is based on normal use and on conventional oil so your argument to me is that synthetic oil gives no benefits or extended oil drains compared to conventional because you guys say it needs to be changed less than that. Totally Baseless Garbage
Big Oil Loves 3000k oil change intervals $$$$$$$$$$
