Is the DVD drive slaved to the hdd? If it is it will slow down file transfers. To fix this, reconnect the the dvd drive on a different channel. Also check in the properties of the ide port controller to make sure it is using UDMA transfer. Other than that, it could be the DVD drive is dirty or having a hard time reading due to misalignment of the laser and will need to be replaced.
