how can i improve flash game performance
cytg111
26,735
16,017
Allright, as we are probably 95% aligned here it is just down to the nidbits ..
A couple of questions though :)
1. Why wouldnt this Flash-JIT, fit in a JVM for example? Or CLI? Depending on system of course.
2. If Flash has a nice JIT compiler, just as the JVM or analog for CLI, why couldnt adobes version perform just as good ? (- and I guess it could, with the same billions of dollars invested into it as java or c# )
I suppose the difference could be coming from two differenct directions, ms and sun started at the borttom, hiring the best language architects out there (Anders Hejlsberg (Dane and Viking) and James Gosling) and Adobe coming from a practial usage scenario evolving the portfolio towards "language" .. the main problem, as always, being backwards compatability .. But just hypothesising here.
Cerb
17,484
33
86
Lack of demand? There's no real use for Flash, outside of specialized applications, most of which are web browsers, and there are plenty of other languages to use in a CLI, or on the JVM.
It's not the billions of dollars (though, that has helped keep Java from becoming irrelevant). It's that Java and C# are not dynamic. They were made for high performance (well, Java wasn't from the beginning, but it has been for a long time, now). Javascript was made for high productivity: less code for a given amount of work done on some data set.
In a couple Adobe presentations I've seen (I'm not a Flash dev), their performance improvement claims were in line with other dynamic languages that later got compilation attempts, like Lua and Smalltalk. Dynamic languages are different than static languages. In a static language, you must either annotate all types, or all types must be inferable by the compiler.
Code:
function gogo( arg1, arg2, arg3) {code} <- typical dynamic
int function gogo( int arg1, short arg2, string arg3) {code} <- typical static
All functions must execute as if type checks were put off until the very last moment, in a dynamic system. Many object-oriented dynamic systems allow this to go as far as allowing existing compiled code to operate on data types that have not yet been created in the system (including one of the first few OOPLs ever created, Smalltalk). In the static language, it must be proven before it can compile.
The big performance advantage is that fixed-size variables can be known memory offsets, and variable-sized variables can be pointers at some known offset. In the dynamic case, the system must always check the type, and be prepared to find relevant operations for it, and execute them. There will be ranges of dynamic code that can be so proven, and get sped up a lot by a native compiler, since those checks can be removed, and parts of the operations can be inlined...but, in practical code, they tend to be fairly small ranges at a time--somewhere, it gets to a point where it can't prove that correctness automatically, anymore.
Code:
a = 2;
b = '5';
In Java, types are strict, and based on common machine types. The compiler knows what type every operation can take (this can be worked around, technically, since everything is a subtype of Object, but that's ugly, bad form, prone to problems, etc.).
Code:
c = a + b;
^ That won't compile.
Javascript has loose typing, so the above will work fine. It should yield, "25," which can then be used as the string, "25," or the number, 25. Now, considering a web browser, and that the web is 99.x plain text, that actually makes a lot of sense. Not using the above as a substitute for math, but being able to mix numbers and strings without a bunch of typecast and parse calls littering much of the code (if you want it as a number, FI, explicitly parse it once at the very beginning, and then leave it that way).
To get the performance JIT JS engines can (browsers are doing it, too), part of what they do is infer static types from what operations are done. However, needing many functions to be able to handle different input types, there are limits on how efficient that can get (IE, there will be some function call that will get stuck with all the dynamic checking), overall, even if most of the types in your code can be 100% figured out.
Then, JS uses prototyping for objects, and they are dynamic, where Java's are static. Java, with static typing, can define an object's layout in memory, on a given machine, and then build the rest of the code around that.
Address { int streetnum, string street, string city, byte state, int zip } can be well-defined in memory. Every one is the same. So it can do things like define streetnum as the object's address + 8, FI. These kinds of things can reduce the access of fixed-size variables to a handful of assembly instructions, and not too much more for variable-sized objects that need pointing to, like strings.
In Javascript, that Address is going to be a dictionary, and require a key lookup every single access, into a trie or hash table. It's not really a defined type of record before the runtime system gets it, but is made as it goes along. You can subtype just by adding a key/value pair to the table (so, what takes a whole new text file in Java, and typically tens of lines of code in C#, might be done with just a few lines of Javascript). Compared to an offset of some bytes, or going to another pointer or two, that's going to be pretty expensive. It will then also have to chase pointers for things like strings, just like a static language would.
Macromedia more or less chose Javascript because it was a fad, at the time. But, if Adobe could start from scratch, and did not choose an ECMAScript*, they still would get a language with most of Javascript's features. An ideal language would look a lot like Javascript, but with strict typing, rather than loose. It's hard to show in small easy snippets, but the difference in code written for sizable projects can be reduced by 10-100x, by not having to fuss with all the typing directly in the code. But, having to keep up with typing dynamically in the system eats performance potential. TANSTAAFL.
* Hmmm. TANSTAAFL, inferable, and inlined were not in the spellchecker dictionary, but ECMAScript was.
bononos
3,944
192
Does that mean an i5? I thought the i3 had turbo, but from some earlier posts, apparently they dont??
I definitely would not buy a new laptop without turbo, since the base clocks of mobile chips are so low.
Could you try out the game at a store like a bestbuy/officemax to check out the performance. You can get some idea of what sort of machine it needs.
Torn Mind
12,086
2,774
i5 is dual core with hyperthreading and i7 is true quad core, with hyperthreading also I believe. I have an i5 work laptop, and it is pretty fast. Shows 4 cores in task manager.
It was the i3 I was not clear about. I think I would rather have turbo than hyperthreading, especially considering the low clocks on mobile chips.
Mobile i7s can be dual cores as well.
Homeles is correct. The quad-core i7s are distinguished by the "Q" in their name. I think the dual core i7s have higher clocks and Turbos than their i5 counterparts, but not much difference elsewhere, although there might be some obscure ones(need to check).
Ketchup
14,559
248
frozentundra123456, to answer your original post (if it hasn't been answered already, I skipped through the segue) Processor is what you want for flash. An i5 would do great, but a Pentium has done ok for the flash games I play. For now, you could select lower quality (if you haven't already) and the game will run better. If she get's tired of doing that, try to find an add-on for your browser that does this for you. I don't know how well AMDs handle Flash, but the speed of the chip is usually paramount with flash, not number of cores.
Aug 11, 2008
10,451
642
Thanks for the information, and thanks to the other posters as well. If I replace her computer, I would probably go with an i5. She is getting by for now, and uses my desktop a lot while I am at work (she is retired).
