How best to measure height needed for CPU cooler?
JimKiler
3,561
206
I want to buy this CPU cooler https://www.newegg.com/Product/Prod...als LLC-_-na-_-na-_-na&Item=35-103-253&cm_sp=
and newegg lists the height as 158.50 mm. I took a ruler to the inside of my Be Quiet Pure Base 600 case and hitting a spot the existing cooler is using i came out with a measurement of just over 16 cm. Do i need to take my current cooler off my CPU to get an accurate measurement? This is not the largest CPU heatsink and fan so it should fit right?
