- Dec 26, 2007
- 11,782
- 2
- 76
Where can I get the residential wiring codes? Is it the NFPA-70 the global one with my state/city amendments tacked on?
A friend paid over $20000 after all was said and done to rewire a K&T house.
That was fine by them though, since their offer was low. Few prospective buyers wanted to deal with that. Depending on the location and the size of the house, I'd drop the offer by 5-digit $.
BTW, as for insurance, most of the insurance companies they called flat-out refused to insure them. One company agreed, but wanted a premium of 4-digit $. Yes 4-digit $. So, it only made sense to rewire.
I've had three old houses with knob and tube wiring. As long as the electrical system is in good condition, there's really nothing wrong with it. I had no problems whatsoever.
Personally, I would have the electrical system inspected by a good licensed electrician. If he says it's good, I would go for it and not look back. Just make sure your smoke detectors are good for peace of mind at night.
P.S. What incoming service do most K&T homes have? 60A or something? I don't I could run a house on just 60A, at least in an area that needs air conditioning. (Mine is a 200A service.)
It was just replacing the meter box, the wire into the meter box and going out to the inside panel. Some work but really only 6 lug nuts. Wiring a house to code, how many wall plugs, wire gauge, what requires a dedicated circuit (microwave, bathroom), ground faults.......I don't have the knowledge.
Well, that kinda was what I was getting at. Around where my friend bought, nearly all of the original homes had K&T, but by the 21st century, most of the homes had been rewired, so those with K&T (or faked rewiring with a K&T backbone) would get significantly lower offers.Well the houses in this area are basically all going to have K&T unless they were updated since being built. Most homes here are pre 1970, with most being built right after WWII during that boom.
GFCI? It would get fairly expensive though, so another plus for rewiring.Unfortunately I need grounded outlets. Luckily most of the home is fairly easy to access from the basement, but it's partially finished so it means I would need to rip up some of the ceiling down there.
I'm no expert, and I'm just guessing, but could this be a warning sign? ie. Could the house have been 60A, later upgraded to 100A with additional outlets added, but without taking the layout of the existing K&T wiring taken into account? If so, then that could make the K&T dangerous and uninsurable.This home is 100A, which would meet my needs as of today. Especially since it's only me to start, with a potential roommate later on.
Hmmm... I think this post demonstrates why one should hire a professional.You do have the "knowledge" - unless that Google thing is too difficult. If you have the capability to do what you said you did, you have the ability to install wiring. Meeting code is as simple as a bit of googling to see exactly what you need to do. "Gee, I'm going to rewire my kitchen" - it's not difficult to see where you need GFI outlets (counter), to see that you need a separate circuit for lighting, a separate circuit for a dishwasher, fridge, and garbage disposal (I think the garbage disposal can be on the same circuit as the dishwasher, but that didn't matter for me, since no garbage disposal), etc. A bit of google & some youtube videos, and anyone who can build their own computer from parts should be smart enough to wire their home. Then, there are the tips: NEVER use that backwiring crap where you insert the wires - always screw the wires down. Even though both methods meet code, the former leads to problems down the road too often (you'd find this with a few searches.) The spacing for outlets is very simple to find - and there's nothing in code about having too many outlets. E.g., the spacing is for the minimum number of outlets in a wall. But, even this has very little to do with actual fire safety - more indirectly, because it avoids the use of extension cords. If you wire your breaker box properly, and wire your outlets and switches properly, then you're extremely unlikely to have a safety problem.
I will say that I did make two errors - one: my stove has a bracket in the back that has a 4 inch large screw. Son of a bitch - when I angled that screw downward near the floor, I managed to have it angled just right to nail the wiring for the microwave. Had nothing to do with the wiring; more bad luck with installing the stove. The other blunder was a last second wiring decision. I KNEW I needed to run another line from a junction box in the attic to the light over the sink. Somehow, the thought popped into my head, "wait, there's still room (to code) in this nearby recessed lighting to hook up another light." Idiot - now the sink light can only be on if all the other lights are on. It's still to code, just not what I intended - I wanted that light to be able to be on by itself. I realized the blunder minutes later - and just after I had a few more rows of tongue and groove on the ceiling. I didn't want to risk damaging the ceiling to fix the error, so I'll do it from above when I put new roofing on (probably this fall or next spring.)
The electrician who wired our house before we bought it did a hack job. The service panels were upgraded to modern one with breakers and larger capacity. However he just connected it all to existing knob and tube wiring instead o rewiring everything with romex. He installed 3 prong outlets but the ground prong is not connected to ground.
Yeah it looks like the panel here was done similar. Upgraded the service to 100A, panel to breakers, and then just threw the old K&T in. No outlets were converted however so I know nothing outside of the few things that have romex (like a GFCI near the wash basin or the garage that is rewired) are grounded.
Are you trying to claim you saved $20000 because you did the wiring yourself? $20000 for wiring a kitchen is horrendously overpriced.And why's that? I probably saved $20,000 on my kitchen remodeling project by doing it myself, and simply didn't stop to think about not adding one of the lights to a particular circuit, rather than running a separate line.
I definitely understand that, having gone through a reno myself. It pays to have:If you think that "professionals" don't routinely make far worse mistakes, and then just hide the evidence, then I've got a bridge to sell you.
Don't get me wrong, there are plenty of extremely competent professionals out there. But there is almost no way, even as an informed consumer, to tell the difference between a competent professional and a sleazeball who just hasn't been caught yet. Way too many idiots leaving five-star reviews because they liked the price, or the punctuality, or the guy's face, never mind the quality of the work (which most people don't bother to check anyway).
I can't tell you how many times I've had to fix the mistakes that "professionals" have made on housing projects...
Just read the post right above this one and ask how much that guy got paid for the job.
Cost me about $250 in my moderately sized house from the same era. The difference between do it yourself & hiring someone is amazing.
Anyway, knob and tube wiring isn't inherently dangerous. In fact, it's quite safe. The problem is that it's inadequate for today's needs.
The house service is just the rating for the home from the power company. You can have 2000amp service and still have K&T (safely even.) The individual leg breakers are what count. K&T is only dangerous know because it was often done with cloth wire which has fallen apart and often the lack of neutral and power coloring on the oldest stuff. In theory if the insulation is still good you could just pull grounds to outlets and make them "work." I wouldn't keep it if I was already in there working on stuff. I may not just auto rip it out either though.
