This is actually a two-part thread:
The first part is about my girlfriend's hot water heater. She takes a lot of baths and never has enough water to draw a full bath. So with all my newfound free time, I'm starting to get around fixing these things.
Her tub is, like most bath tubs, about 20 or 25 gallons. She has a 35 gallon hot water heater. She runs out of hot water about 1/2 the way up, so about, on average, maybe 10 gallons or so.
Her hot water heater is a two-element, 4500W, 35 gallon hot water heater. Obviously, something isn't right here. It goes without saying that she doesn't take a bath if the dishes or washing machine are runing.
I started playing around with it and I was going to reset it, in case one of the elements isn't working, which I think may be the case. So I went to go kill the breaker and none of her breakers are labeled.
I assumed this to be a flagrant violation of electrical code. While the 2003 code isn't available online, the NEC 2005 draft is. According to article 408.4, Circuit Directory, it is a violate of code not not legibly identify the use or purporse of each switch.
It is also worth nothing that the hot water heater isn't on the appropriatly-rated breaker. Assuming 4500W @ 240 VAC, the rms current draw is about 18.75 amps. The manual specifically states that it should be tied to a 25A switch. Now, all the breakers are either 20 or 30 A. Putting it at 20A would not be an acceptable tolerance, in my opinion, so I am going to assume that it is not any of the 20A switches. However, 30A is a 33% tolerance beyond the nominal operating condition, which to me seems awfully high. Is that another violation of the code?
So I have two questions
1) can I safely reset her HWH without having to turn off the breaker? I'm not about to start pulling every 30A switch at 2 AM. It's been bothering her a lot lately.
2) I want these switches labeled. Her super is obviously incompetant. He has been over here twice, and both times he caused more harm than good. They were both plumbing issues. The first service call was because the little routing-thingy that switches between the shower and the bath tap stopped working. He knocked in a wall before he decided to call a plumber, who said that it was a 10 minute job that was turned into an hour because of the amount of damage the super caused. The scond service call was because the ceiling was leaking, and all he did was put a plastic wal-mart bag taped to the ceiling. If at all possible I don't want him anywhere near the electrical system. Is there a way to get them out here TOMORROW and have these labeled? I am not going to be blamed for pulling switches and destroying something important.
